allmotorbeasteg6
Member
ok heres my situation, im either thinking of building up a jdm b18c meaning im going to fully built the bottom end with pistons, rods, resleeve and bore the block to 85mm, and also have it balanced, flywheel, and clutch. as for the head, im probably just going to install from itr cams since im putting so much money into the block first. on the otherhand, get a jdm type r and leave the block to way it is which is stock. im probably just going to a clutch and a flywheel. i havent gotten an idea what imma do the head due to the type r costing so much. so here's my question, is building the gs-r block a better idea even though the head just have itr cams or is getting a type r motor a better idea due to the fact that the type r has other goodies that the b18c doesnt come with? any opinions will be greatly appreciated....
