Using pr3 pistons and rods in a ls crx??
  • Thread starter Thread starter auditt225
  • Replies Replies 9
  • Views Views 946
auditt225
So Im rebuilding an ls motor in my crx. I went ahead and bought pr3 pistons and rods to put in the block. Will it fit Or will it hit the valves? Im new to this honda stuff. Thanks
Then why are you asking if it will fit you just stated it will raise compression you new this the whole time. PR3 belongs in jdm b16a siR. What is your setup for ALL MOTOR. MAybe i can help?;)
right now im having trouble removing the pins from the pistons. Any recs? Of do I need to take it to a machine shop?
Take it to a shop. The pins need to be pressed out and use a special tool(although you can get away with using sockets).
The pistons should work as long as the cams aren't too aggressive. Even then, you can just clay it to make sure.
