VTEC and rev limit early...
  • Thread starter Thread starter OBD0SiR
  • Replies Replies 3
  • Views Views 959
OBD0SiR
I have a 91 cive hatch with a b16. its runnin on a pr3 (not chipped, i already checked). The problem is that vtec is engaging at 4500 and its hittin th "limiter" at 7200-7600...and it tops out at 115 which is about 6900...i am so confused. There are no CELs, the valves are perfectly adjusted. good spark...timing is a bit advanced but nothing major. all plugs, sensors, and connectors are correct. oil level is full. what could it be. I am completely stumped. OH, and BTW the vtec screen was checked and is spotless. and vtec doesnt seem to pull as hard as my old SI...thanks
iave an aftermarket tach, and i know that it is not that far off if it is off at all. I dont know anyone with the same computer set up, but i will look into getting another one i suppose...thanks
