what causes this...
  • Thread starter Thread starter D See 2
  • Replies Replies 5
  • Views Views 973
D See 2
ok, for the past 2 weeks, as i have been driving, my car will all of a sudden have a really sharp jolt and the motor shuts off for a split second. one time when it did it, the motor completely shutoff while driving on the freeway. any pointers? no check engine light... 93 octane fuel... ;)
I bet something in the ignition is wrong, check your plugs ans wires. Maybe check your cap and rotor.
i vote cap and rotor... same thing was happening to mine, until one day it wouldn't start anymore.. the rotor ended up breaking off in the cap! hehe, the parts are cheap for a rotor and cap.
that is the SAME exact problem that i had...it was the IGNITER (inside your distributor). costs me around $100 to get it replaced by a mechanic. its worth replacing just in case. it got to the point where my engine would die at 80mph! it felt like the engine was seizing. this igniter problem is common in older hondas. there was even a recall on them for the 4th gen civics.
And the G2 Integras. It's easy enough to change yourself, but if you get a Honda part it will cost more than $100.
