Hey all, I need some help here... I'm working with a 98 HX that we put a B16 in. It runs ok, but feels like the timing is really retarded. When I pull codes, I get 4 long flashes, then 1 short flash, pause, 3 short flashes, pause, 7 short flashes, pause, 9 short flashes. I am working with a P61 ECU ran into a skunk2 obd2-obd1 conversion harness. I know that we should be getting a KS code, since we have no KS in (came broken on the new motor), but the other codes don't make sense. I can't even find a reference to a code 47 or 49, does anyone have any ideas? I know that KS codes will deaden your timing, but I am not even getting that code from the ECU... I could really use some help here!
