ls v-tec eg
just got done putting teg ls motor in eg hatch with gsr head.. whats a good piston to go with? an anybody know wat a ls vtec eg should run in the quater mile???
thats what the arp rod bolts prevent...your not supposed to shift it above 8k or else you will spin a rod bearing and put a perdy hole in your block
spinning the motor that high with high lift cams and 12.5:1 compression (via ctr pistons) + 9k = BOOM after a shot period of time.
A gsr girdle or =, would've helped.
i thought only some f and k series came with factory girdles?
