what psi should i spray my coats at ?
  • Thread starter Thread starter ssl2k
  • Replies Replies 5
  • Views Views 10K
ssl2k
I know youshould spray your primer at like 20-25 right?
what about base coats and clear coats?
btw, I have a HVLP gavity feed gun
nathan
20-25 Is fine, I usually turn it up a little more for the clearcoat to atomize it better.
thank god you told him the right answer befor some noob told him 50psi or somthing dumb. I spray high build at around 13-15 psi but i am runnning a 1/2 airline on a big tank so i flow more air at a lower psi.
yip i run very low for primer as well such as around 15 psi. For basecoat i run abot 19 psi and about 17 to dust coat the last coat if it is metallic. clear i run at around 21 to 23 psi
