ps
I still want to throw rocks at this fcking car.
Quoted post[/post]]
ps
Quoted post[/post]]
Quoted post[/post]]
ps
and i want to roll your WRX down a cliff
please note that no WRX's were harmed in the making of this post.
Quoted post[/post]]
and it weighs like 2 metric tonnes.
Quoted post[/post]]
...can't be happier.
Quoted post[/post]]
cocktail? is that like gearlube or something?
you bought a scion....... and the ugliest one at that.Quoted post[/post]]
and takes 3 seconds to change gears
Quoted post[/post]]
The Scion beats it routinely, as do most Kias, off the line. It accelerates like Clayton's Legume until the turbo kicks in .. and it takes about 3 seconds to do that. So the Scion gets 3 car lengths on me easily off the line, then I'm hitting the brakes to avoid parking the WRX in his trunk.
Shifting a WRX takes finesse in all gears - But it's just like driving a Porsche, Lotus, Ferrari etc... These cars aren't intended for head-to-head drags. You hit the gas, bring up the rpms, clutch in and shift - The shift time in these cars may take you to idle everytime. If you keep the revs up and the boost on, you CAN make a great shift, but it's not easy, and it's not conducive to street driving.
I pulled out onto a main road a few days and nearly got broadsided by a truck that careened about a blind corner - I saw him in plenty time, put the gas down and waited. And waited. And waited and when the turbo finally got it's pressure, the truck was almost ontop of me.
the WRX is useless until you've sunk at least $2k into it.
Quoted post[/post]]
my buddys WRX (you know, the one that ive worked on) sucks. he ran it almost out of oil the other day.
before that, it blew tons of smoke out when he stomped on it. mods? vishnu up/down pipe (i put them on) and a hallman mbc.
the car has 60K miles on it. the interior rattles. the suspension is rusting. while there are no visible leaks in the engine bay, its also oxidized to hell.
lovely car, i must say. im with steve, though. the turbo is quite anemic at lower rpms, and the mirage beats it off the line. then again, i can launch EASILY at 5K rpms on my toyos with no bog. he wont catch me until about 35/40. forget about corners. even with almost new as430s on his car he cant touch my entry and exit speeds.
The STi barely has suspension mods. Slightly stiffer springs, thicker sway bars, inverted struts, and far stickier tires. This makes the car a "turning car".adding onto what steve says, unless its an STi its not a turning car, either![]()
Quoted post[/post]]
That thing might make people stop and puke, this this thing will make people stop and go damn what is that sexy little thing.
Quoted post[/post]]
