will a si harness fit on a d15b6
  • Thread starter Thread starter jdmcivicef
  • Replies Replies 5
jdmcivicef
jus got a d15b6 and i wanted to kno be4 i tried it .... thanx
Yes. Your only wiring problems in this gen is the DPFI / MPFI wiring. And of course VTEC wiring if you're going to go that route.
The connectors may need to be transplanted if the two are from different years.
i have dpfi.... could i jus swap manifolds off the D15B6????
....thanx
as long as you styay with the dpfi most of the dseries parts are interchangeable. once you get to the mpfi you will have harness probs like celerity said.
The SI harness will fit on the DX but the manifold needs to be changed over to MPFI. The harness will not hook up to the DPFI mani. But if your already running the MPFI mani just swap the MPFI mani onto the B6 and slap it in.
Yeah just make sure to use OBD-0 injectors due to the clips. Thats if you are MPFI Si and just swapping out manifolds. If you don't change the injectors off the D15B6 you will have to change out the injector pig tails to obd-1 grey plugs and eliminate the resistor connection due to saturated injectors.
