WTB - B18 Built Motor
yes sir..fully built for boost.oilpan to valve cover,but like above what are u looking to spend
alright here.-------ARP rod bolts,main,head studs nippon 9;2 1 pistons,eagle rods,golden eagle block gaurd..hondata headgasket,brian crower full valvetrain,,dual springs,ti retainers,new oem valves,an valve seales,p an p,5 angle,crower st 3 camshafts,an i will also include the moroso valve cover,all new gaskets on everything.new oil pump,water pump,time belt ,tensionner,
elderbrock intake mani,with new elderbrockim gasket,dsm 450 injectors,unorthodox racing under drive pulley as well as alt pulley,an i will include the ECU,it is a pr4 that has most recent tune for that motor,it was tuned on chrome, for 6lbs with t3/t04 50 trim setup july 14th 2011that is the most of it..if i had to throw a number out i would say 1200,more if u need it delivered,if u want give me ur email an i will send ya pics
has roughly 1200 miles,sorry to say sir,no paper work,built it for a friend,then he ended up needing $$$$ so i ended up with it,an i doubt he kept any receipts an such,,,
