Yonaka Aluminum Lower Control Arms
  • Thread starter Thread starter TorontoJdm
TorontoJdm
Features:
LCA's are an essential part to your car's suspension. When lowering your car your wheels will start to butterfly inward at the top which makes your tires ride on the edge. This increases wear on your tires as the sidewalls are the weakest part of your tire. This also means that there is less tire on the ground which means loss of traction around turns. LCA's reduce camber so that more of your tire touches the ground, keep your tires from rubbing your fender and allow for a wider wheel and tire combination. These LCA's provide light-weight performance with an enhanced appearance to your suspension.
Yonaka controls arms are designed to greatly improve the feel and response time of your vehicle. Forged with 6061 aluminum alloy with new performance polyurethane bushings, they are a direct bolt on fit requiring no modifications.
They are 2.5 lbs lighter than the OEM pieces.
They will fit the following vehicles:
1988-1991 Honda EF Civic/CRX
1992-1995 Honda EG Civic / 1993-1997 Del Sol
1990-1993 Acura Integra
1994-2001 Acura Integra
1996-2000 Honda EK Civic *Unavailable
Warranty:
1 year against manufacturing defects
Price: $110 SET
FEEL FREE TO CALL OR DROP BY FOR MORE INFORMATION.
We Have Many Other Parts in Stock for Almost Any Car!
