Original thread from: www.preludepower.com
I wrote this thread to help out all those who want to goBoostedorTunetheir 3rd Gen Ludes. I noticed a lot of new people are starting to ask about Boosting right off the start, so I took it upon myself to help out all theNooBiesand try to cut down on the massive overposting of others saying"Search!!!!". I hope this points you in the right direction. I make no warranty's nor guarantee's, this is a collection of information I collected from the site and other experienced Boosted 3rd Gen'ers who all have done their homework and to whomI Publicly give Thanks and Credit too for all your input and wealth of knowledge.
I will continue to update and edit this thread as necessary as new information comes to surface in the Tuning and Boosting Dept for 3rd Gener's.
In order to Tune 3rd Gens for Boosted applications and or just tune for better performance we need to upgrade to OBD1. This thread is put together from alot of the material and experience from those who have done it before us and will continue to after this post.
To date there is no one chipping our stock ECU's for performance, and it will be easier to do the conversion versus trying to Chip it and Tune it.
Our cars have these ECU's from the factory:
90-91 2.1 Si preludes with the B21 came OBD1 and a Pk3 ECU.
*Note: You 90-91 Prelude guys do not need the OBD1 Conversion Harness as your car is wired to plug straight into any OBD1 ECU.
88-89 2.0Si preludes came OBD0 with a PK2 ECU.
Originally posted by Bobnova - Having read the entire thing (took a while
) i would add one (1) thing, all b20a5 motors are obd0, regardless of year, while all b21 motors are obd1.
1. We must convert from OBD0 to OBD1 which makes our cars use any 92 -95 Honda ECU's.
a. We need an OBD1 ECU - PR4, P28, or PO6
b. A 4 wire O2 Sensor
c. Conversion Harness
2. Have the ECU chipped so it can be programmed for Tuning. For those of you who do not know what an ECU is click here: pgmfi.org • Index page
3. Here is another option for ECU's, thank you to Bobnova for his contribution to this item. It is a Do It Your Self ECU with Tuning options out the AssMe SomeQuestions! You can buy the Kit for $140.00 and build it yourself or you may buy it pre-assembled for a little more from the site I have put down on this thread. Make sure to read up on it though, because it is a lot more difficult to set up, but once you understand it, it will be the best thing you probably ever changed on the Lude as per the customers who have already bought it. Here is the Link:
*Please note that Bobnova recommends you purchase the kit with the V3.0 Board, for Megasquirt N Spark - Extra, or Megasquirt2
Well I will let you read what he had to say about the unit:
*Quote from Bobnova:
I had problems with mine, mainly because i didn't buy the new (v3) board that can read the TDC sensor directly, i did get it to work though.
It ran about the same, really, the stock ecu is well tuned for stock.
The timing map you have to make yourself, i dug up an integra map and put the values off it into megasquirt for a basemap, for fuel it will generate one for you based on engine displacement/rpm/hp/torque, and it's generally quite accurate for n/a.
It is HIGHLY advised that you get a basic wideband sensor, the $200 in-line controller ones work well, and megasquirt can read them directly.
To wire it in i bought a prelude ecu ($10) and hacked the guts out of it, then stuck the megasquirt into the case, and made a obd0-MS conversion harness using the connectors, it took a while, but wasn't hard.
Generally speaking, it goes on with some, but not much, difficulty. Mine was rather of an odd case, there is another guy on the msefi boards with an integra (same damn sensors), and his went right on no problem.
Here is a picture of it:
You can find a local shop to do it or go online and find online performance shops to do it for you like this one:
Or you can chip it yourself for the DIY's here is the link: http://www.pgmfi.org/twiki/bin/view/Library/IntroductionToECUChipping
Hondata wiring harness for this is roughly about $140.00 + s/h and use this with the Hondata s100 w/boost unit which costs $445.00.
3. We need to use a P28 ECU(civic ecu) or a 92 Integra Non-Vtec ECU(he said fairly cheap) which is called a PR4 - make sure that it is not the 90 - 91 or else it will not work. You can even use the PO6 ECU's.
4. Buy or make a OBD0 to OBD1 conversion harness - $115.00 to $149.00 depending on who makes the harness. I wrote to rywire.com and a guy named Ryan said he can do it with the pinout I emailed him for $115.00 shipped.
Example:
www.boomslang.us
www.rywire.com
5. You will need a 4 wire O2 Sensor for the conversion as well so the ECU will understand what it needs to do. You can go to the junk yard and cut off the factory connector so that you can wire it up to the Conversion harness, then just plug straight to the 4 wire O2 sensor. Here is picture of what I did to get mine:
a. The first connector is the harness for the ECU.
b. The second is obviously the 4 wire O2 sensor itself. I got the connector and O2 sensor at the junkyard for $20.00.
Here is my PR4 ECU and the OBD1 Conversion Harness(www.Boomslang.us) I got for it.
and so forth...By the way some of the these links also sell the ECU's you will need to do the conversion.
Here is what the OBD1 Plugs look like:
Or do the pinout yourself and make your own harness for free here is the the pinout: I would like to personally Thank, Lud4ever for giving his updated pinout to the forum
OBD1->OBD0 - Function
A01 ->A01 - #1 injector
A02 ->A07 - #4 injector
A03 ->A03 - #2 injector
A04 ->N/C - VTEC solenoid Valve
A05 ->A05 - #3 injector
A06 ->N/C - O2 Sensor Heater Control
A07 ->A12&A14 - Fuel Pump Relay (FLR1)
A08 ->N/C - Fuel Pump Relay (FLR2)
A09 ->A11 - EACV
A10 ->N/C - EGR solenoid valve
A11 ->N/C -
A12 ->N/C -
A13 ->B06 - Check Engine Light (MIL)
A14 ->N/C -
A15 ->B01 - A/C Clutch Relay
A16 ->N/C -
A17 ->N/C -
A18 ->N/C -
A19 ->N/C -
A20 ->B02 - Purge Control Solenoid Valve
A21 ->B15&B17 - Igniter Power Source (IGP1)
A22 ->N/C - Igniter Power Source (IGP2)
A23 ->A02 - Power Ground (PG1)
A24 ->A04 - Power Ground (PG2)
A25 ->A13 - Main Relay IGP1 (IG Power)
A26 ->A18 - Logic Ground (LG1)
A27 ->N/C -
B01 ->A15 - Power Source (IGP2)
B02 ->A16 - Logic Ground (LG2)
B03 ->N/C -
B04 ->N/C - Service Check Connector
B05 ->B08 - A/C Switch (ACS)
B06 ->N/C -
B07 ->N/C -
B08 ->N/C - P/S Pressure Switch
B09 ->B13 - Starter Switch Signal (STS)
B10 ->B16 - Speed Sensor
B11 ->C01 - CYL Sensor
B12 ->C02 - CYL Sensor
B13 ->C03 - TDC Sensor
B14 ->C04 - TDC Sensor
B15 ->B10 - Crank Angle Sensor
B16 ->B12 - Crank Sensor
D01 ->A17 - Back Up Fuse
D02 ->N/C - Brake Switch
D03 ->N/C - Knock Sensor
D04 ->N/C- Service Check & Ignition Timing Connector (SCS)
D05 ->N/C -
D06 ->N/C - VTEC Pressure Switch
D07 ->N/C - Data Link Connector
D08 ->N/C -
D09 ->B14 - Alternator
D10 ->B19 -
D11 ->C07 - Throttle Position Sensor (TPS)
D12 ->N/C -
D13 ->C06 - TW Sensor
D14 ->C16 - O2 Sensor
D15 ->C05 - Intake Air Temperature Sensor
D16 ->N/C -
D17 ->C11 - MAP Sensor
D18 ->N/C -
D19 ->C15 - Sensor Voltage (VCC1)
D20 ->C13 - Sensor Voltage (VCC2)
D21 ->C14 - Sensor Ground (SG1)
D22 ->C12 - Sensor Ground (SG2)
you have to short pin D04 to GND in order to check your CEL codes. btw, this harness has produced no codes in my car, other than the one i was getting before i even installed it.. damn TPS..
After all that is done Make Sure to either have the car towed or if you want to, limp it to the closest dyno shop, and have them TUNE the car to get the desired Horse Power!!! If you want to street tune prior to this then you are on your own and will be in a world of hurt when the Engine goes Bang!!!!! **PLEASE REMEMBER - TUNING IS YOUR FRIEND!!!** That has been stressed to me countless times and I will pass this very vital information onto you!
To answer all those noobie questions, it has been established that All 3rd Gens have the OBD1 compliant Distributor, so we do not need to buy a new one.
This method is the most highly recommended modification for Boosting and Tuning. It is possible to Boost with the old FMU route but it must be done right and it is almost the same cost to do.
*Since we are talking about Tuning, we might as well cover TurboCharging and the Parts for Boosting, here are the choices as of the date of this write up*:
1. Have a local shop custom make a Exhaust Manifold and Downpipe to your specific needs.
2. Call and have lsdmotorsports.com sell you their kits and or parts for your Boosting pleasures. LSDMotorpsorts is the only one who is actually carrying custom made parts for 3rd Gen's on their shelves. I personally have purchased a Exhaust Manifold and Downpipe from them. Mike(sales@lsdmotorsports.com #1-877-573-6686) - is the guy I talk to every time I call and he has been extremely helpful and non-biased about setting up my car. I highly recommend them and I know you will be happy too! (sorry just wanted to give my little testimonial...hahaha!!)
3. Ebay for a lot of miscellaneous parts like Turbo's, Gauges, MAP Bypass links, Oil feed and return kits, used ECU's, Conversion Harnesses(I recommend emailing the Harness sellers to ask if they can build you one with the pinout above), and high flow injectors. And so forth.
4. Here is a picture of the www.LSDMotorsports.com T-25 Manifold and Downpipe:
These parts are made of all stainless steel metal and are of good quality craftmanship. You have other options, I am only using my setup as an example for all you wanting to know - parts etc..
I decided to upgrade my Radiator fans for more room and better cooling before I put in the Turbo here are the pictures and a little write up:
Ok here is some pics to give you an idea of what I have to contend with:
So what do you think?? Should I pull the upper hose and just let some leak or what??
*Update ------------------------------------------------------------------------------
Ok, it took me a while(2 1/2 hours), but I got it done and it works great! Definitely pulls a lot of air and is much quieter! So, here are the pics:
I like a lot!!!!!!! I recommend everyone do the upgrade, it frees up a lot of room for future upgrades .
Here is what to do:
1. You have to unbolt 4 bolts on the top of the fans, each one has two on top and then three at the bottom of the radiator. Two of the bolts are just a untighten situation and the third is a complete removal.
If you have A/C like me, you will need to unbolt two of the A/C lines from the smaller fan, and unbolt the little funnel looking thing that shoots air to the Alternator.
If you are an Automatic like me, you will need to unbolt the two lines on either side of the green and white O2 sensor connectors. You will need to be able to move them when it comes time to remove the fans.
2. You will want to get a 90 degree angled pick(they are cheap tools you can get at any local hardware store) to take off the connectors, which are way down in the engine bay so get ready to squeeze your way thru.
3. Once you have the connectors off and all the bolts undone, you will need to remove the top Radiator hose and overflow hose and bend them away and put a rag on the top hose as not to loose to much coolant, the little one will just bend away and keep it facing up.
4. Now start with the bigger fan first and just wiggle it back and forth and make sure to look at every angle as it is coming up because it will snag on something and stop coming out. Then once you have the main fan out, start to work out the smaller fan toward the left where the bigger fan was and then pull it out the same way.
Walla!!!! there out. And now just install the fans that will replace them. Oh yeah!! Make sure to cut off the OEM connector from the OEM fan so you can butt connect them to the upgraded fans.
The Blue/Black wires on the OEM fans are (+) and the Black wires are (-). Just use butt connectors and I recommend getting some of that heat shrink tubing to cover them after they are connected.
And just an added note: You can actually fit two 12" fans side by side(as you can see from my pictures), there was more room than I thought when I ordered these two. It does not hurt to have bigger fans pulling the same amount of air or even go with a 14" and a 12", I will probably end up changing up later on, but this will do for now.
FYI: The A/C line that you see going over the upper radiator hose is not suppose to do that, I removed the hose again after I took pics and placed it back under the hose where it was suppose to be in the first place.
(oops!!)
Update!
I bought it off of ebay from this ebay store called: whiteperformance1 - http://stores.ebay.com/whiteperformance1
1-877-288-3881
They sell a lot of these fans and are pretty damn cheap. I was quite surprised when I saw there price. I called them because when I wanted to order them the sold all there fans on ebay, at least the ones I wanted to buy.
The total for both:
12" - $23.95
10" - $20.95
Shipping - $13.95
Total was: $58.85shipped.
Whiteperformance1 - warranties these fans for (3) years!!!
You can't even get one flexlite fan or slimline fan for that price!
Here are my Injectors for my setup 450cc
Now while we are on the subject of Fuel, you will need to upgrade the Stock Fuel Pump. Here are the two options you have:
1. TRE-341 255 LPH Fuel Pump fits these cars: 88-96 Honda Prelude
This is the link to the website:
http://www.treperformance.com/FuelPumps/TRE255FuelPumps.html#341
255 LPH Fuel Pump:
TRE-340
Our Discount Price:
$69.99 + $10.00s/h
2. Walbro 255lph Fuel pumps are one the main pumps that alot of boosted cars you to give them more fuel. You can find these almost anywhere on the net especially on ebay. I would give you a link, but I am sure you can pull this up on ebay fairly easily without my help.
On the average these fuel pumps are $99.00 + s/h.
As for the model number for which pump to use I have learned that you can use these pumps from these cars:
92 - 96 Prelude - GSS-341
90 - 93 Accord - GSS341
88 - 91 CRX - GSS-342
*And for the record, my setup will be:
T-25 DSM Turbo w/7psi wastegate, www.LSDMotorsports.com - Manifold & Downpipe, PR4 ECU(chipped and Tuned on Crome), www.Boomslang.us OBD1 Conversion Harness, 450cc DSM Injectors, 255lph fuel pump, 12" and 10" 2.2" 1250cfm Slim Radiator Fans, I will add a Wideband O2 sensor and gauges at a later date, that is why I had the extra O2 Bung installed. A Custom made side mount Intercooler. And of course the necessary gauges and oil feed and return kits. All this is on a Stock B20A JDM engine and stock internals.
There are many Turbo sellers out there that offer rebuilds for used Turbo's and brand new Turbo's as well. It's not hard to find them on the net, or you can call your local shop to inquire about how much they charge.
For those of you who do not understand Turbo Charging your car here is a link for you to read up on: http://www.preludepower.com/forums/showthread.php?t=221037
Here is a link that will explain the different types of Turbo's:
http://www.homemadeturbo.com/tech_projects/turbo_tech/
If you buy a Used Turbo, here is a link to a guy who sell's rebuild kit's for the most common Turbo's, He also sells Turbo's as well and if you don't have a common Turbo, I am sure they can help you find parts for it:
http://www.gpopshop.com/kits.html
Here is a link for those of you who need an adapter plate to use a turbo to a certain Exhaust Manifold, for example: Use a DSM T-25 on a T3 Exhaust Manifold.
http://www.bmcrace.com/products/adapters/
And if you are not sure if you want to Add an Intercooler or not check this link out:
http://www.preludepower.com/forums/showthread.php?t=236648
And after you decide that Turbo Charging is for you then clik on this link so you know what Parts you are going to need: http://www.preludepower.com/forums/showthread.php?t=229697
Here is a link to convert to the 4 wire O2 Sensor for the those who are using the Stock ECU with an FMU. This is only for the 88 - 89 Preludes, not for the 90 - 91 Si Ludes since they are already 4 wire O2 from the factory. http://ludicrous2_0.tripod.com/how_to/oxy/index.html
And for you guys who want a FMIC(front mount intercooler) this is what your car may have to go thru to make it work, take a look at this link: http://www.preludepower.com/forums/showthread.php?t=216152
*Update - 04-25-2006 - Charge Pipe Bends and Length's
a. Planeman01 - used (4) 180's pipe bends and (2) 45's pipe bends
b. Rudeludenotmeanthough - used 5 180 degree bends and the legs were 10 - 12" inches long. He had to cut and weld to make them work.
Here is a link discussing "How To Make 450cc DSM Injectors Fit":
1. http://www.homemadeturbo.com/tech_projects/dsm_injectors/ *Please note that as far as the wiring goes it does not apply to 3rd Gen's read the update below -
*Update - 04-27-2006 - DSM Injectors Hook up:
After some research, I have found out that DSM 450cc's will plug straight in to our existing harnesses and that we do not need any splicing of anything due to we already have a stock resistor box on our 3rd Gen cars. So, all you need to do is buy some good rebuilt 450cc DSM (Peak and Hold) injector's.
*Turbo Charging a 3rd Gen Automatic!!!* 05/02/06
Update on upgrading the Torque converter!! 09/11/06
I spoke to a local shop up here in WA(Precision Torque Converters - 253-288-2233)
According to Neal the tech, he said that the Honda Torque Converters were very strong and are capable of handling some boost. However, I asked him what was involved in beefing up the torque converters? He said they just look for weak spots on the TC they add extra welds so as to not have the thing fly apart under the extra Horse Power.
He also recommends flushing the whole system out to get any particles that may have gotten into the tranny and adding an inline filter on the transmission fluid line to keep the TC from getting damaged.
For this upgrade they are charging $212.16 (which includes the Core fee if you do not give them your core. Core fee - $30.00)
So, for those of you wanting to Turbo Charge your Auto like Me! We have a cheaper option!
Sean
I spoke to a sales rep. at a shop in New Jersey who specializes in Upgrading or "Bullet Proofing" a Honda Prelude Automatic Transmission to handle the power of boost. He informed me that they have in stock and designed a new torque converter and all other miscellaneous parts for all Honda Automatic Transmission's. You will have to drop your tranny if it is still on the car or if you are buying a JDM tranny, have it shipped to them and they will modify and install all parts and then ship it back to you, ready to be installed and be on your way!! I was informed the tranny will handle 425hp @ the wheels!!! and that their is no middle ground when it comes to upgrading Honda transmission's. The upgrade is $3,600.00 - Ouch!!! I knew it was going to be expensive, but Damm!! Anyways, I wanted to answer the question for those few of us out there, that have Auto 3rd gen's
Here is there site: www.levelten.com - And here is the link direct to the Honda Kit Upgrade: http://www.levelten.com/press/12_00_honda_acura_PTS.htm
*Edit: 5/22/06
I have discovered that other than dropping your whole Auto Tranny and shipping it to these companies, you can just pull the Torque Converter on your Auto and ship it to any of these companies and they will rebuild the Torque Converter to handle the extra power and torque from the Boosted engine.
These Performance Torque Converters start at $500.00 to about $700.00
Honda Prelude High Stall Performance Torque Converter:
IPT Custom High-Stall Converter. All years and models
Increase performance and reduce ET by .5 to 1 full second over a stock converter. IPT is able to custom modify your converter to suit the characteristics of your vehicle. Please note that this is a modification service- you must ship your existing converter to: IPT 1105 Rt. 23 South Wayne, NJ 07470 Turnaround time is approximately 4-7 business days
Price: $479
Here are the companies that specialize in Honda Performance Torque Converters:
1. www.jmousa.com
2. www.importperformancetrans.com
3. www.levelten.com
by originally posted by
SiBen - Man, auto tranny SUCKS. I just got my turbo installed in my auto Si with H22 swap and the torque converter keeps slipping. I made 138whp and 151ft/lb of torque at 5500rpm with 5psi boost. This is the first time a honda engine made more torque than hp. My torque curve dropped like hell after 4500rpm and my hp curve dropped off after 5500rpm. fuel cut-off is at 7200 so it's not a problem with that. THIS SUCKS.
And I hear this grinding noise whenever my car is just beginning to accelerate or just beginning to decelerate or cruising at closed throttle. I can't figure out what it is. But it's robbing a lot of power in the drivetrain. Could it be the axles or the tranny? Can someone tell me what could be wrong with my car?
This is what happens when you do not upgrade your Torque converter when Turbocharging!
And for those of you who want to see how to install a turbo on your 3rd Gen, here is the link for an actual turbo install of our Beloved cars + an extra link to show how to setup a junkyard setup that will work as well:
1. 3rd Gen Turbo install: http://www.preludepower.com/forums/showthread.php?t=235660
2. Junkyard install and parts: http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
3. 3rd Gen DSM Ghetto Setup:
For those of you who wanted to know, you can successfully install a complete Eclipse DSM Turbo system in a 3rd gen and get it to work. His setup up was from a 91 Eclipse DSM. This setup is from a member by the name of Fisher Price.
Here is a picture of the only one known to date to make it work:
Quote: "Well for those who said it couldn't be done...here it is....im finished and here are the pics i promised...it fits like a charm...there was some minor grinding i had to do to the block to get it to fit but its nothing major...all minor work...the front mount will fit but only with the bottom bolt only...the top half of it would have to be cut off....O2 housing clears the alternator fine but i think i will make a heat shield for the manifold and the O2 housing so i don't fry the alternator and the power steering line...not bad for 10 bucks on the manifold...free turbo and 4 hours time of beta testing....for all you who said it couldn't be done...well its just been done!!".
In closing, make sure you know what you want to do power wise for your car. You must understand a little bit of what you are doing, before you start asking who makes kits?, or were can I get parts? or how do I do this?
After you have come to a solid conclusion and are ready to start your project knowing what you are willing to sacrifice or not, then you can start to purchase the parts of kits that will fit your specific Turbo Charging needs and desires. Also, so everyone is aware; you can Turbo Charge without an intercooler. There are people on here who are still Non-Intercooled and are running this setup as a daily driver, for example the site Administrator: Dave - hondaprelude88 Here is his current setup:
He is currently using this setup as his daily driver and has had this setup for almost 4 years! So, to answer all those who say they just want a simple Turbo setup, it is very doable! Just remember, you are limited to the amount of Boost you can push(7psi) and with this setup, if you do not go OBD1-Conversion with 450cc injector upgrade then you must use the MSD BTM module to handle your timing and protect from Detonation(it sounds like a can full of marbles shaking around). I would recommend asking these guys for their advice since they already have done this. Here is the link to his thread on this setup: http://www.preludepower.com/forums/showthread.php?t=205829
Just remember what works for say example: Me - 1Funryd, will not be the same as what you may want to do to your car when it comes to Turboing yours.
I hope I gave you enough to think about and contemplate before making this huge step.
Here are Pics of those 3rd Gen'ers who have complete Turbo setups:
Tonbaker -
This was Tony's original setup Non-intercooled however; he had an www.snowperformance.net - Boost Cooler kit on his setup which was what he used to cool his charged air to the engine for two years non-intercooled. The stage 1 kit costs $299.00.
Tony's Setup:
Engine:
b20a5 block
b21a1 head, mild portjob
B-18 intake cam
B-16 outer valve springs
Pauter Rods
Weisco Pistons 8:5:1
Turbo Setup:
Precision SC61
Tial 38mm
HKS SS
Gigantic FMIC
Alky Control Methanol Injection
NX 65 Shot
Ludespeed Manifold
Ludespeed front engine mount
Tuning Setup:
550CC injectors
Hondata S200
Walbro 255 lph pump
Bigger fuel lines and NO banjo fittings anywhere.
Exhaust Setup:
3inch all the way back
Apexi N1 muffler
Drive Train Setup:
ACT XT Pressure Plate
ACT 4 puck race disk
Stock Lightened flywheel
Weight Reduction & Transfer:
Aluminum Sunroof replacement
Aluminum front bumper support
Lots of misc removal, AC, Power Steering, Heater Core, Sunroof, Seats, SeatBelts etc...
Power Output Updated 11/08/06:
Daily driver 400+whp and 380lbs torque 3rd gen turbo lude.
Updated power curve after Dyno - October 17, 2006
This was 20lbs of boost with a 50shot.
Note: Above 20lbs the car was running super rich (10:1). It needs to be tuned some more. So hopefully after my next tune session i'll make 380 on boost alone.
Slowly but surely.
Planeman01 - updated September 18, 2006
Planeman01 had said he thought he knew what setup he wanted and then when he actually got it, he wanted something different. He also said, after it was Professionally Tuned, his engine blew because we had a cold snap up here in Seattle, which in turn caused an extra 1psi higher than what his car was Tuned for. So, make sure that you know your environment also when going this route. Every place is different and a car will respond differently to different environments especially when it comes to Performance cars.
Planeman01's Setup:
Engine:
Stock Block and Head
action 2ms clutch
rebuilt tranny
new clutch master cylinder
new slave cylinder
Turbo Setup:
Straight T3 .42/48
Ludespeed manifold with 2000deg F coating
Ludespeed downpipe
TiAL 35mm wg .5bar spring
2.5 inch exhaust
a muffler that i thought looked cool
dsm injectors (390 cc)
walbro 255lph fuel pump
tuned on crome
ludespeed front motor mount
new radiator
Johnny racecar FMIC painted black
2.5inch charge pipes
golden eagle sandwich adapter
stainless braided oil feed
autometer boost gauge
greddy type s bov
blitz bual TT turbo timer
Power Output:
i put down 179hp atw and 187 tq. on 5.5-6psi
B20luda -
B20luda Setup:
Engine:
Rebuilt B21
Turbo Setup:
my setup its runnin 8 psi
ludespeed manifold
ludespeed intercooler and DownPipe
I have an EGT guage airfuel oil pressure and boost
Walbro 255lph Fuel Pump
450cc Injectors
t3 t4 turbo with a big compressor housing
Hondata for Tuning
Update:
90 2.0si fully built turbo b21
Tuned by me dynoed 200whp on 6psi currently installing a better turbo GT30R and a 3in DownPipe with 1000cc injectors..
Power Output:
200hp @ 6psi
CADster's formerly Bgerk's Setup:
www.LSDMotorsports.com - Manifold Kit(DIY) I had welded togther
Intercooler and Piping
Rebuilt and Polished 14b
Polished DSM BOV
Downpipe
SAFC II- for Tuning
Wired-up MSD-BTM - for Tuning
GM 2-Bar map sensor
walbro 255lph fule pump
modified Power steering line to go over and down on the driver side
Zex Plugs
*Kept all A/C, Power steering, Cruise Control.
Power Output:
158 w.h.p and 159 torque - Dynoed @ 8psi
Boostedlude3g -
(Pictures not available at this time)
Boostelude3g's Setup:
Engine Rebuilt:
Engine Misc.:B20 block with b21 head and intake manifold
crower rods
weisco pistons
H22 dual valve springs
powder coated red valve cover
ZEX plugs
NGK plug wires
MSD blaster 2 coil
Turbo Setup:
Fuel & Tuning:
P74 ecu/hondata
precision 680cc injectors
Exhaust:
Open
Drivetrain:
ACT 6 puck
removed A/C, power steering, condenser fan and gutted trunk.
Power Output:
193hp & 181tq @ 7psi
I found this on another members post so I thought I would post in this thread:
1989 Honda Prelude Si Turbo
Atlanta, Georgia, USA
Car:
- 1989 Honda Prelude Si Turbo (16V DOHC 2.1L)
Engine Mods:
- Garrett T3/T4 hybrid turbocharger
- LudeSPEED Liquid-Air Intercooler (using A/C condenser as heat exchanger)
- GReddy Type-S BOV
- Wiseco (7.5:1) Forged Pistons
- Total Seal Piston Rings
- Pauter H-beam Forged Rods
- Bored 30 over; iron-sleeved back to stock displacement
- Vortech FPR
- Skunk2 Adjustable Cam Gears
- LudeSPEED Turbo Manifold
- LudeSPEED 2.5" Downpipe
- Polished and Balanced Crankshaft
- 3 Angle Valve Job
- O-ringed head, Copper Head Gasket
- ARP Head Stud Kit
- Unorthodox Crank Pulley
- APEX'i S-AFC -
If you want to see his whole page here is the link:
http://www.geocities.com/rolin5_jason/prelude/
I hope you all enjoy this write up!
After all this we can run the standalone fuel management systems and or Boost whatever other system that you prefer and boost and tune our cars properly and be able to tune them so as not to blow up our motors.
For all your Turbo needs go to this site below, Mike @ LSD is very helpful and will do everything he can to meet your performance needs. He is the only shop (that I know of) the carries performance parts and accessories for that are 3rd Gen specific.
We are Your one Stop Shop for all of your turbo needs. From the TurboCharger to the oil lines that run the fluid through your turbo, we got it
I hope this helps all you newbies and oldies to Turbo Charging your 3rd Gen Lude!! Enjoy!
Sean
1Funryd
Example:
www.boomslang.us
www.rywire.com
A09 ->A11 - EACV
A11 ->N/C -
A12 ->N/C -
A14 ->N/C -
A16 ->N/C -
A17 ->N/C -
A18 ->N/C -
A19 ->N/C -
A27 ->N/C -
B03 ->N/C -
B06 ->N/C -
B07 ->N/C -
D05 ->N/C -
D08 ->N/C -
D10 ->B19 -
D12 ->N/C -
D16 ->N/C -
D18 ->N/C -
Here is what to do:
Update!
1-877-288-3881
The total for both:
12" - $23.95
10" - $20.95
Shipping - $13.95
255 LPH Fuel Pump:
TRE-340
Our Discount Price:
$69.99 + $10.00s/h
Sean
*Edit: 5/22/06
Price: $479
1. www.jmousa.com
3. www.levelten.com
Tonbaker -
Tony's Setup:
Engine:
b20a5 block
B-18 intake cam
Pauter Rods
Turbo Setup:
Precision SC61
Tial 38mm
HKS SS
Gigantic FMIC
NX 65 Shot
Ludespeed Manifold
Tuning Setup:
550CC injectors
Hondata S200
Walbro 255 lph pump
Exhaust Setup:
Apexi N1 muffler
Drive Train Setup:
Slowly but surely.
Planeman01's Setup:
Engine:
action 2ms clutch
rebuilt tranny
new slave cylinder
Turbo Setup:
Straight T3 .42/48
Ludespeed downpipe
2.5 inch exhaust
tuned on crome
new radiator
greddy type s bov
Power Output:
B20luda -
B20luda Setup:
Engine:
Rebuilt B21
Turbo Setup:
ludespeed manifold
450cc Injectors
Hondata for Tuning
Update:
Power Output:
200hp @ 6psi
Polished DSM BOV
Downpipe
SAFC II- for Tuning
GM 2-Bar map sensor
Zex Plugs
Power Output:
Boostedlude3g -
Engine Rebuilt:
crower rods
weisco pistons
ZEX plugs
NGK plug wires
MSD blaster 2 coil
Turbo Setup:
- custom AutoLab turbo kit
- Garrett T04E/T3 50 trim
- 8 gauge 304SS log manifold
- tial 38 mm waste gate with open dump
- tial BOV
- front mount intercooler (don't know the dimensions)
- aluminum piping
Fuel & Tuning:
P74 ecu/hondata
Exhaust:
Open
Drivetrain:
ACT 6 puck
Power Output:
Car:
Engine Mods:
- GReddy Type-S BOV
- Vortech FPR
- 3 Angle Valve Job
- ARP Head Stud Kit
- APEX'i S-AFC -
Sean
1Funryd
