34diesel34
Import Tuner
I finally got my B16a into my 91 crx si. It's turning over but will not start. Everything is connected correctly, battery is fully charged, brand new starter, brand new plugs & wires, and I can hear the fuel pump when the key is in the on position. I'm using the same p28 ecu that I used on my sohc vtec obd1 conversion. I was using obd0 injectors with the resistor box when I had the sohc engine in. Since the B16a I have is obd1 and came with injectors I'm using those and removed the resistor box.What is the problem here?
