Andrew
Active Member
Hey everyone, as you can see from my sig, I've recently been uploading some of my personal write-ups on different things regarding mostly EF's.
Heres my How To on making those gauge cluster lights really shine. Unfortunatly enough, and I'm really sorry, my motor is out of town getting built, so I don't have any before and after pics. But please be assured, it looks MUCH brighter and clearer.
Lets get to it.
You'll need:
-Small screwdriver. the screws are phillips head, but if it's small enough you can use a Flat head.
(Thats it!)
1. Start by locating the 4 screws that hold the gauge cluster cover on.
2. Remove them-
As for these two, just pop the little covers off and unscrew them.
3. As you start to pull the gauge cluster cover off, you'll feel some tension. Don't yank on it. Just look back behind it and you'll notice that your Hazard switch, Light dimmer, and rear defroster switches(if it's an SI) are holding it. Just unplug them and it will come right out.
4. On top of the gauge cluster you will find a small white plastic strip, the bulb housing. Unscrew the 2 screws holding it down and lift it up.
5. With this up, you'll see a reddish colored light defuser. Remove it. As you can see, that light defuser does a lot more than just turn the light the color orange. it actually blocks the majority of the light from the bulbs.
And thats all!
If you want color in your cluster, take a piece of plastic, whatever color you want, and cut it to size and put it where the OEM piece was.
Like I mentioned before, check my sig for other How To's, and as always, Comments are welcome.
-Andrew
Lets get to it.
You'll need:
(Thats it!)
2. Remove them-
And thats all!
-Andrew
