1996 Prelude Rev issue
Discussion in 'Prelude' started by lowrollin82, Apr 4, 2008.
  1. lowrollin82
    lowrollin82 New Member
    I'm looking at getting a 96 prelude from a guy but when you start it, it revs high then drops. It does this the entire time its running. He told me that he swapped the engine for one out of a 1997 Accord and its supposed to be a h22. I have never had or messed with Hondas before so I have no clue where to even start looking to fix the problem. Any help would be great.
  2. nootrac22
    exeter pa
    first thing, check the coolant system. my prelude had a f'ed up radiator and would do that. My accord did the same thing after blowing a heater hose..
  3. 94H23BB4
    94H23BB4 New Member
    Many things could contribute to the idle surge. It is common in 4th gen prelude and honda accords.
  4. t3t4delsol
    t3t4delsol New Member
    York, Pa
    clean the screen inside your idle air control valve with carb cleaner
  5. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
  6. lowrollin82
    It sounds like its nothing major, so I think I'll get it. Thanks for the help and I'm sure I'll have many more questions as I get into modifying the car.
  7. drocca97
    drocca97 young grasshoppa
    Florida
    Just to state the obvious: Definitely make sure its an h22 and not an f22. Not trying to be a smart ass or anything but that would really be some piss in your corn flakes.
  8. lowrollin82
    How do I find out which engine it is? I am only going on what I have been told.
  9. t3t4delsol
    York, Pa
    engine code is stamped on the front of the block at the bell housing to the left of the header
  10. nootrac22
    exeter pa
    h22 = dohc
    f22 = sohc
  11. lowrollin82
    If it is a f22, how good is that engine? And would the same things told above be why its revving like it is?
  12. nootrac22
    exeter pa
    f22 is a great engine. will run for ever as a stock dd. also takes boost well. the revving is almost definately a coolant issue.
  13. drocca97
    Florida
    Yeah definitely a reliable engine but not if your looking for power. i drive an accord with an f22. It runs great but i have the same problem with revving and vtec. I would definitely be upset if i were expecting an H22 and got an f22.
  14. nootrac22
    exeter pa
    that's not what it was made for. It's supposed to have enough power to haul around a family sedan, be reliable and econimical. It does those 3 things, and does them well.
  15. drocca97
    Florida
    True. Very true but he's not driving a family sedan. Its a prelude. I guess if he just wants a practical car then f22 is right up his alley.
  16. Uncle Buck
    well i wouldnt go to that extent...... because the F22b is DOHC and the H23 is a DOHC..... so ya just so there is no confusion for anyone else
  17. drocca97
    Florida
    Actually the f22A1 is dohc too. Didnt think about that. Still its not the h22 like lowrollin82 is being promised. The type r accord did have an h22a in 97. Maybe thats where it came from. Hmm...:huh:
  18. Uncle Buck
    since when was the F22a1 a DOHC....... hmmmm apparently i missed the memo:mellow:
  19. drocca97
    Florida
  20. Uncle Buck
    i believe that sir is a typo....
