94 civic hatch
well, yeah if i swap, im definately upgrading braking and suspension, but i wouldnt do those before swapping.
I'm kinda suprised nobody said this yet, but why dont you just do a D16Z6 swap first, then save your leftover $$$ for a turbo set up that will walk all over
most b series swaps.
if you get the full Z6 swap you get a much better tranny/engine and ecu it's a basic plug and play swap to get you used to your car and knowing more of what's involved in engine swapping.
hes right
lol good idea, but what does the z6 pull out of?
and how much am i looking at $$ for the complete swap w/o turbo for now.
lol good idea, biw what does the z6 pull out of?
and how much am i looking at $$ for tha complete swap w/o turbo for now.
500 bucks they come from a 92-95 ex or si
92-95 civic ex or Si and del-sol Si, as for price I dont really know what a fair price for a full swap would be, but less than 1G for sure.
you can get a turbo kit for about 1500, and i wouldnt go over 200whp on a stock motor d series that is. but you will get those numbers easy
if i get the z6 and turbo is but want more than 200HP what do i need to do?
change the internals?
im actually considering the d16z6 now, hhaa
ok ill tty omorrow bro, thx alot for everything today, 1st day on honda swap and i love it! =]
pe@ce
I agree with the other posters here when they say stick with the D-series. It's the easiest swap for a beginner. If you go with a swap from any of the other engine series (B, H, K, etc.), then you have to get a new transmission as well...
incorrect. in the del sol si the b16 is present. but in the del sol s i beileve that's where the d16z6 comes to play.
incorrect the del sol s has a d15 in it the si has the d16z6 in it and the del sol with the b16 just says vtec on the back
my bad than i was always told the si was the b16 version of the sol. and that the s had the d16 but that the regular del sol was the d15 one.
Del Sol S = D15
Del Sol Si = D16Z6
Del Sol Si VTEC = B16A3
It's the same trim level system they used for the 92-96 Prelude...
so how much HP is a d16z6 have?
and with all stock internals and everything, how much PSI could i run (safely)?
125hp or I believe 108 actual to the wheels. 7psi.
