Basically, i have a built LSVTEC setup, stg 2 cams 12.6 mm lift on the intake side, 11.9 on the exhaust, 11.4:1 comp, B16 head with polished ports, shotpeened rods, and its borred to 81.5 mm.
How safe is the stock ecu going to be in regards to detonation ?.
I was looking at pherable.nets products and they do custom basemaps for your engine setup, How safe are they gonna be ?.
And also looking at the Apexi vafc2, looks pretty good for the price am I right in assuming it would be good enough for my setup ?.
Mind you im not looking to acheive 5 more whp from tuning, I just want a detonation safe setup, im pretty sure I can probably do that by simply retarding the ignition timing on the dizzy and listening for knocking. Because im not running a turbo setup, i doubt ill need that extensive of a tune, its just a street car.
Thanks alot
Mike
Thanks alot
Mike
