I don't recall the exact numbers on the mains, they were within spec. I torqued with my torque wrench according to my Helms. I re-used the OE bolts. I did not hone the mains. I believe the crank was ok. I did not measure the main or rod journals.what were your oil clearances on the mains? also how did you torque? did you use studs on the mains or bolts? did you line hone the manins? how was the crank? did you measure the main and rod journals?
sorry for the 21 ? but all very important
I did notice when I pulled the pistons the bearings were starting to shine. My friend was saying they should have still looked like new. They are suggesting I ditch the ACL bearings and match OE colors to what the block says for the mains and use Reds for the rods.
I did a compression check today just to rule out the timing tensioner that loosend and I still have 250psi across the board so that is ok. Maybe this weekend I'll get around to dropping the pan and pulling the bearings to inspect them. I'm thinking i'll be able to still get the upper main bearings out with the crank still in.
Please ask questions, offer suggestions.. I'm about fed up with this thing. I just want to drive.
Another stumbling block is the power it was making. Only 160whp. The B16 with CTR cams and same bolt ons made 175whp (same head too just CTR cams instead of these blox HSL).
