B18B, ODB1 P75 ECU, modified stock harness in an EG
Ok, the swaps in and I have a CEL (6 flashes - Coolant Tempature Sensor)
My temp gauge works, the car doesn't overheat but the fan doesn't kick on.
Hard to start when cold (but will), then when warm it idles at about 1200rpm...no fluctuation
Unplug the fast idle, the car shuts off. If the keys is still on and I plug it back in I can hear a faint whistle/ring and the valve open/close under the throttle body.
Where is the coolant temp sensor? I thought it was on the thermostat housing, but now I'm thinking thats for the gauge...so theres got to be 2, right?
-Also, yes, I've bled the coolant-
