b18b1 into 97 civic ex
u will need this mount on the timmng side of the engine from the 99-00 si
99-00 si rear bracket
99-00 top tranny mount
any bseires lower tranny mount
99-00 si timming mount on the engine
any b-seires shiftlinkage
upper and lower radiator hoses 90-01 integra
90 non abs integra axles with a dc2 94-01 midshaft
delsol ac bracket(if u want to keep your ac)
96-98 ls dizzy
jumper harness with a dx or p75 ecu
sohc iacv valve
sohc injectors
any b-seires starter-90-01 integra
and last u will need a 96-98 integra altantor an belt
if u want to keep your power steering u will also need an 94-01 integra power steering pump an bracket.
Let me first start with saying I am an american service member stationed in German so and buying has to be online.
Ok I have these parts so far;
dc2 94-01 midshaft
96-98 ls dizzy
sohc iacv valve
sohc injectors
I guess I have to buy these to finish the install;
99-00 si rear bracket(were can I buy this)
99-00 top tranny mount(were can I buy this)
99-00 si timming mount on the engine(were can I buy this)
delsol ac bracket
96-98 ls dizzy
jumper harness with a dx or p75 ecu(were can I buy this item)
96-98 integra Alternator and belt
delsol ac bracket
96-98 ls dizzy
96-98 integra Alternator and belt( bought)
yea u can use any ac bracket but to keep your ac u will need a delsol ac bracket so u can use your singlecam compresser
I am asking for any help possible to an internet link to these parts so I can order them. I live in Germany and have little to no access to these parts over here.
jumper harness with a dx or p75 ecu(I think I found this part on line)
Ok due to living in germany my resourses for parts is limited to online. So please a link to these parts would help alot.
I think one of these should work for this
Rywire - Online Store
or this one
Hasport Performance Online Store
I just bought these also for the install
I believe I found the part #'s for the parts.
Timing Belt Mount
Part # 11910-P30-000
Transmission Mount (top) **Update: All hydraulic trans use the same mount, therefore this mount is not required**
Part # 50825-S04-000( is this true?)
Rear Mount (t-shaped bracket)
Part # 50827-S04-N10 or this I hope they are the same part?
timing belt mount is known as a post mount. its the mount that bolts DIRECTLY ON TO THE BLOCK with 2 studs sticking out of it.
the tranny mount is not necessary if your ex motor *d16y8* is 5sp. you can reuse that mount.
The upper or lower mount off the tranny?
no u cant u need a b-series lower tranny mount and a 99-00 si top tranny bracket, please dont try arguee because i have the swap done on my 98 ex
cool but I was told I do not need #6 as my ex one will work. Is this true or not? The rest are ordered but the ac bracket is on back order.
I ordered it just like you said as seeing you already have it in your car I will go with your info.
yes u want to do it right the first time. u can use all your old ex motor mounts as long as u have all the si brackets. u can use any b-series ac bracket for now just to get all the motor mounts in your swap. if u need any help just pm me
