Spankyomally
I have a B18C and I put in a B20 crank. After plugging the specs into the calc. I have a piston to deck clearance of -0.002. My question is if I use a Cometic gasket that measures 0.035 will that be acceptable being as it is larger than the reccomended distance of 0.030? My goal is to keep the compression up w/o creating clearance issues. Wth these specs I got 11.57:1 with a rod/stroke ratio of 1.55.
Thanks in advance!
Thanks in advance!
