Or not. I haven't been cleared to post pics yet! <_<
Here's what you do:
1. Cut the OBD2 [1 big plug] connector from your d16(or the GSR) DIZZY. I cut mine right where the wires met the dizzy. DO NOT CUT YOUR STOCK HARNESS
2. Cut the OBD1 [1 med 1 little]connectors from the engine harness that came with your engine, or goto a junkyard and cut it off one there.
3. The connector wires connect as so:
OBD2 Plug wires that connect to OBD1 plug wires
solid white------------------------------------------solid white
orange(peach to me)------------------------------orange
yellow/green stripe---------------------------------yellow/green stripe
DARK blue-------------------------------------------DARK blue
black/yellow stripe----------------------------------black/yellow stripe(bigger wire)
white/blue stripe------------------------------------white/blue stripe
orange/blue stripe----------------------------------orange/blue stripe
aqua blue/green stripe-----------------------------light blue/green stripe
aqua blue/yellow stripe----------------------------light blue/yellow
I used double crimps to connect them for now, but soldering them would be best.
4. Wrap in electral tape to your hearts desire to sheild from moisture.
Now, one end should plug into your OBD1 dizzy and the other should plug up to your stock wire harness.
I did this today, and finally after a month of work......the civ prowls the streets again!
![Notworthy :worthy: :worthy:](/styles/default/xenforo/smilies/notworthy.gif)
I will post pics as soon as THEY let me....
