1988crxswapp
alright here is my questions i want to make my b18c as responsive as i can so my idea is to up the compresion a lil bit with a thinner head gasket but i want to stay on pump gas then i want to put the best set of cams in i can get and looking at cams it says i should replace the bearings im helicopter mechanic im good with my hands but never done any engin internal work is this something i can handle on my own with good manuals? also what size head gasket can i get away with also can i replace the barings on the crank by just dropping the oil pan and diconecting the connecting rods and droping the crank out and leaving the engine in? do i need to do anything special when replacing those bearing like machining work or nething or can i just slap them in and bolt everthing together and go???????????? any advice is apreciated i have purchased some books and manual anything i might need ???? thankyou
