D16Y8 turbo build
Discussion in 'Engine Building' started by turbodhatch, May 10, 2007.
  1. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    heres my build on my d16 let me no what u think if u dont like d serise then just stay out of this bitch
    BLOck, wiseco pistions 911 comp
    eagle rods---------------^
    machiend block bored 20 over
    balanced stock crank
    block garud
    ARP head studs
    HEAD.
    comp cams drag street lift dont remeber the specs dont feel like going down stairs and lookin ha
    comp springs and retainers
    new oem rockers
    valve job and new seals
    TURBO sHIT,
    top mount turbo mani custom made
    gt35r turbo
    330 cc injectors
    greddy fmic
    custom down pipe
    greddy BC
    chiped p28 tuned with hondata
    bigger fuel pump dont remeber what size
    prolly some other little shit i didnt post
    if any one is seeing pics just say so and ill post em
  2. dtob
    dtob New Member
    I think that the Z6 oil pump flows better. Might want to look into it. I'm pretty sure the y series oil pumps suck and that's why they spin their rod bearings more easily than the z6. Would be a cheap upgrade and good insurance.
  3. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    ok.. i dont really like typing so i just kinda rushed it
    its just a post guy
  4. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    i also have heard the same but i still to this day have not found one other persone who used a z6 oil pump on a y8 block . i mean will it even work?
  5. dtob
    dtob New Member
    Go to d-series.org those guys are the kings of d series engines and making them run better. I'm pretty sure its there that I saw the y series engines have crappy oil pumps and the z6 would be better. D series block is a d series block. Z6 oil pump should just bolt right up.
  6. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    i dont have a oil problem. upgraded fuel pumps arent always good. i was just wondering if u can put a z6 oil pump on a y8. b.c to my knowldege you cant.?
  7. dtob
    dtob New Member
    Sure you don't have an oil problem but its good insurance. I don't have an oil problem with my b18b but I put a type r oil pump on it anyway.
  8. A_SeP21
    A_SeP21 New Member
    nothern indiana
    y7 head on y8 block
    my friend has a 98 4-door with a y8 block with a y7 head with a garrett t3/t4, and all he has is 440cc injectors, a block guard, and arp head bolts and it runs a 12.8 on 12 p.s.i. so i was wondering if its really worth puttin all the work into it if i could just do that, and have a dependable ride?
  9. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    hell yea it is dude that ceap money with a built motor
  10. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    the z6 pump will fit but there will be no place for you to put a oil dipstick. like the other guy said check out theoldone.com. i used there advice on ther oil pump and i have not had a problem. (knock on wood)
  11. erebunicrx
    Bristol ct
    also how much power you shooting for? i think a 35r maybe alittle too big. your not going to get much higher than 425 stock ports anyway.
  12. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    what are u talking about.. thats got noting to do with the question i asked.. ?
  13. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    im shooting for about 350 400 hp. alot of ppl i no have used 35r's are there set ups on about 15 to 30 lbs of boost. thats my range for this motor
  14. erebunicrx
    Bristol ct
    no reason to use a 35r for that amount of power. 50 trims make more than 350. i would go with a gt28rs if you looking for that amount.
  15. stuntstere
    stuntstere Member
    You are going to need bigger injectors then 330cc. You should go ATLEAST 550 cc with that type of build. Also the gt35 will be pretty laggy on a d16. You should go with a 50 trim or the gt28 like stated above and you will get better spool characteristics and you should be able to hit your goal.
  16. turbodhatch
    turbodhatch yo moma
    oh. - amelia
    thanks for the info guys. keep shooting it out im eatin it up. im just going buy on this build what i have seen work for ppl. but listin to every ones advise doesnt hurt at all..
  17. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    just curious but why would you run a y7 head on a y8 block? what happened to the y8 head? Also dude I don't know about the z6 oil pump in the y blocks, but I am thinking if you really wanted to upgrade the oil system in anyway couldn't you just port the oil pump to improve flow a bit. Also I have heard of some guys running toga performance oil pumps. But the dude is right the y oil pumps suck. I was running an NA y8 with a cai, and a cat-back, and spun the rod bearing. It leaked oil but when it happened it was a quarter or a half quart low.
