Do your brakes suck?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Loco Honkey, Jun 10, 2004.
Would there be any interest in this?
  1. Yes.
    100.0%
  2. 0 vote(s)
    0.0%
Thread Status:
Not open for further replies.
  1. Loco Honkey
    Loco Honkey Banned
    Would there be any interest for some serious brakes that fit under 15" and 16" wheels? I'm not talking a "junkyard" setup using Corrado rotors and Accord wagon/ ITR calipers... I'm talking a genuine big brake setup with some serious calipers (or the option to use your OEM calipers), a choice of three pad compounds, SS lines, and racing brake fluid, all in one box, developed under real racing conditions to ensure that the components you get in your system are designed to work in harmony with each other.
  2. pissedoffsol
    if it comes with 4 piston calipers
    and will BOLT on
    and clear my 15x7's
    and is under $1000
    i'm in
  3. Claysion
    Claysion Junior Member
    www.fastbrakes.com can set you up with alot of cool stuff, including 4 piston calipers drilled and slotted rotors and a rear disc conversion if you need it.
  4. Claysion
    oh yea and for less than a thousand, but not much.
  5. pissedoffsol
    im aware of fast brakes and willwood... but they aren't what im looking for.
  6. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    It all depends on the price....
  7. Claysion
  8. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    I'm fine with my Ex knuckles / corrado 11" rotors / modified ITR calipers
  9. brc80
    brc80 Senior Member
    Southern California
    Id be in, if the price was right.
  10. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    What are you looking for that Brian doesn't do?
  11. Loco Honkey
    Loco Honkey Banned
    lol... B, you've spent upwards of 20K on the Sol, and you still think there's parts out there that just "BOLT on?" About the only thing that is, is your oil filter. ;)
  12. pissedoffsol
    lol the oil filter? nope.
    had to put the sandwhich thing together. haha
    next?
  13. phunky.buddha
    Dallas / Fort Worth, TX
    Sure, I'm interested- but I'm very happy with my FastBrakes setup too. It performs very nicely.
    B- my 4 wheel setup from FastBrakes was only $1042 shipped, and that included stainless lines for the Wilwoods too. If I went with blanks, it would have been $100 cheaper.
  14. driver1
    driver1 Senior Member
    id be interested but also would corrado rotors fit on my 94 accord? caue id be interestedin doin that to if it would work....never heard about it...and the wagon claiper how much bigger are they?
  15. BigJ
    I need better brakes, but I'm more on a tighter budget then under 1000.
    My set up I'm saving up for is Integra brakes all around on my crx, and I'm upgrading to hp+ pads, ss lines, and brembo blank rotors. Biggest I can fit under my 14" wheels. Also I'm upgrading to the integra mastercylinder/booster.
    But if you can come up with a better set up in a box for under 500 that'll actually make me stop faster, not lock up faster, then I would probably look into it.
  16. Loco Honkey
    Loco Honkey Banned
    Actually, *I* put the sandwich thing together. ;)
  17. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    if you really are considering making an upgrade kit, make sure that you remember that things like the Teg spindles are not the same as the civic spindles and so on.
  18. H22AdelSol
    H22AdelSol Senior Member
    san diego, california
    I just upgraded my brakes because my swap melted the front caliper, wore the pads down way to fast and warped my rotors after 6months.
    Integra spindles
    gsr calipers upfront
    axxis brake pads
    ss lines
    gsr brembo cross drilled and slotted upfront
    normal size brembo cross drilled and slotted in rear
    new oem calipers for rear
    new master cylinder
    new brake booster
    new proportioning valve
    new check valve
    dot 4 fluid
    :D
    very nice setup
    expensive but worth it
  19. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    make some for other cars like prelude and accord :thumbsup:
    o yea lightweight rotors that arent drilled and have good cooling in the package would be nice!
  20. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    I think my brakes sustained permenant damage on rt 17. lol. I should have done a better job cooling them off.
    I would definitley be down for a nice kit.
Thread Status:
