b18a1build
Gay username^
right, all i am doing is adding length to the socket itself, not the actual torque wrench...
The distributor only goes on one way. Towards the fire wall is advance and towards the front of the car is retard.
It is a bolt and play combo. Just finished my swap up. Easier then you think .usually the headgasket causes the overheating
not the other way around
headgaskets are wear items, they eventually go bad from use
do some more research on the H22/F22 combo
from what I have read its not a bolt and play frank motor
