Dual MAPs?
Discussion in 'Civic and del Sol - EG and EK' started by efhondakid, Jan 24, 2009.
  1. efhondakid
    Akron-Canton, Ohio
    Just got done installing some 440cc injectors on my friends boosted Sol and I noticed he has two MAP sensors. One stock OBDI on the TB with the missing link spacer and another OBD0 running from a T from the FPR vaccum source. WTH is up with that?
  2. Fitec Motorsports
    Fitec Motorsports New Member
    Ohio
    Is the MAP sensor on the vacuum line to the FPR wired up to anything? The only thing I can think of would be that this one was used to give a signal to an electronic boost gauge.
  3. efhondakid
    Akron-Canton, Ohio
    Now that you say that I bet thats whats it for, Ill have to look more closely at where the wires for it go.
  4. delslow15
    delslow15 New Member
    north canton
    hey you didnt put those injectors on my car me and ricky did duh
  5. efhondakid
    Akron-Canton, Ohio
    :fuckyou3: Damn n00b.
  6. Briansol
    pointless. you don't need 2 map sensors. map's don't create the vacuum... the vacuum exists in the line.
  7. efhondakid
    Akron-Canton, Ohio
    Right so why in the hell would there be two?
