Electric superchargers for Integra Type R (DC2) engine B18C6
Discussion in 'Forced Induction' started by lunaka, Sep 22, 2006.
  1. lunaka
    lunaka New Member
    Hi,
    I have an Integra Type R (dc2), engine b18c6, very tuning, with elaborate head, compression ratio 11.8:1, cams, complete mugen exhaust, mugen ecu, mugen airbox, big throttle body, fuel pressure regulatore, etc..
    Do you thing the electric superchargers is it right for my car?
    Someone has tested it ?
    When the electric superchargers is turned off the air will be insufficient in how much the tube turns out the much narrow because of impeller ?
    Regards
  2. pissedoffsol
    they are useless, a waste of money, and simply don't work.
  3. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    just get one and tell us how it works
  4. OneSlowEK
    OneSlowEK New Member
    If your car isnt from japan, its not a DC2 -_-, i thought a type r came with b18c5 not c6. And when you mean elaborate head what does that mean? Compression ration 11.8:1 isnt that stock?
    Slap a turbo on it youd like it, crank the boost to 30 psi
  5. pissedoffsol
    There are other countries that people live in besides the USA dude :)
  6. jeffsciv23
    Wa
    if the point of your post is just to be a dick then save it.
    11.8:1 is kinda high to be stock, they came 11.0:1 but since you know so much about hondas i bet you knew that ^_^. sounds like he just put some pr3 pistons in the block with the type r rods, because that is the ballpark CR when done. sounds like he has a decent all motor set-up and with the term "elaborate head" i would think he is meaning upgraded valvetrain.
    electric superchargers are pretty much a waste of money. kinda just a gimmick where they explain it so that in theory it sounds like it would work but in reality it is more of a restriction then anything.
  7. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    ohh nooooeees! my posteses have been stol3d!
  8. GSRCRXsi
    MD
    pr3 pistons would lower compression in a type r.
  9. jeffsciv23
    Wa
