91_stylin_civic
Member
I have a 91 hatch with b16 J1 cable trans. I just completed the swap and took it for a test drive. The car has all gears but when im in any gear the shifter has excessive side to side movement. When im in 2nd the shifter can be moved to look like it is in reverse. Im using avid shift linkage. The linkage will only fit on one way right? The bushings for the linkage is new energy suspension. Has anyone else had this issue? Thanks in advance. Between my two cars im having the worst luck
