First swap suggestions...
Discussion in 'HYBRID -> EG-EK / DC' started by jacomp, Oct 21, 2009.
  1. jacomp
    jacomp New Member
    PA
    Hello all, I'm new to the honda scene as far as the performance part of it. I am restoring a wrecked 98 civic DX with real low miles....has the wimpy D16Y7. Upon finishing the body and paint probably want to do my first swap here a few months down the road. Looking for the easiest one to get some good power without many mods and custom work. From my research and learning I'm leaning towards B16A or B16A2 as being the best move....understanding I need OBD2. My past has been working on american muscle, but I really want to step into the foreign car scene and I love hondas. Any suggestions or help will be greatly appreciated!
  2. jacomp
    jacomp New Member
    PA
    Also curious...any real difference between the B16s and B18s as far as doing swaps?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Most B series swaps are pretty similar, certain model engines, and certain model car combination have some unique quirks, but aside from that they are the same. In a 96+ I wouldn't put anything less than a 1.8+ in it. If the car is still sitting on OEM suspension, imo you'd do better to upgrade there, then the brakes, tires, then get a new engine. It will make the car ahndle better with more power, and will make it a lot of fun to drive till you get the engine.
  4. eg6sir
    IMO.. go w/ a b18c..
  5. Dark93DX
    Dark93DX New Member
    B.C.
    B18C would be the best stock B-series engine to swap, unless you want to get into engine building a B20vtec or something.
    Of course, a K-series would be better:p
  6. CivicPitbull
    CivicPitbull New Member
    hey i have a 1994 civic cx that has a blown headgasket on thwe stock engine and need to know what i need to drop in a d16y7 engine i have can anybody help me out with what i need to do the swap??
  7. 99sidude
    Ohio
    ^ start your own thread :disgust1:
  8. intenseneal
    intenseneal New Member
    B16s are weak IMO. Go with a Ls vtec swap or a B18c1. I have a B18b1 Ls in my 98 and its not too bad at all. The B18b1 or B20 will bot right into a Dx and you have the right wiring harness. Plus the B20 and B18b1 are much cheaper than the B18c but Vtec rocks.
  9. civicorbin
    civicorbin New Member
    nah go with a h series in that car it will give v8's a run for there money. way more power and tourqe than any all motor 1.8l will offer. its worth the extra moneythey make good street cars. unless you are lloking for a road/autocross car then go with the gsr
  10. bsbllpss
    bsbllpss world dominator
    Omaha, NE
    my two cents.. go with the gsr no doubt you see b16s all the time now and there boring, besides if your gonna go with the b18 gsr its a perfect low compression setup for boost later on down the road if you dont wanna go boost later then get the type r with the lsd may be about a grand more but who cares shes badass
  11. shdw b18c
    shdw b18c New Member
    CALI
    GSR B18C in ek plus TURBO FTW!!!!!!!!!!! or TYPE R B18C All Motor FTW!!!!!!!!!! remember B18 or K20 nothing else
  12. h22a91civichatchswap
    h22a91civichatchswap New Member
    Cedar Rapids, Iowa
    if you are looking to do a good b series swap i would make an ls vtech with the b20 block and and b18 water pump and oil pump and b16 head brian crower offers internals for that build and you can get the head dowels for like $10 on ebay the dowels being for the b16 head. if you arne't looking to do that much work i'd go with the GSR b18c other wise i'd try out the new k series engines with the obd2 but you will have to get the k pro i haven't done a k but i've heard really good things about them person ally i love the h series engines
  13. Matts96HB
    Matts96HB . Moderator VIP
    Thread is getting a little old, but I'll bite..
    My recommendation is a GSR (b18c) swap. Easy to perform in the EG chassis, making it a great candidate for your first swap. Get an OBD1 engine, bolt it in, plug in the ECU, perform a couple wiring mods, and you're off.
