gsr x civic
hey i need some input on what i can do to better this setup without spending cash on upgrading the block, so here's my plan:
i have a greddy 18g turbo kit, 375hp fmic, turbo timer, 255 fuel pump, s200, fpr, and that's pretty much it.
what i'm probably going to do to lower compression to compensate for the stock pistons will be to get an hks headgasket (82.5x2.6mm) which should help. would this help anything at all, or will it end up just causing complications?
now im wondering if i'll be safe with 310 injectors @ maybe 7 or 8 lbs. my goal is at least 220whp.
help is appreciated. thanks in advanced
