.secret.AZN.man.
I have a complete 94 LS complete car sitting in my drive way and I'm planning on swaping the motor into my 92 Civic CX. I have done many swaps before but this is my first for a honda. I have gathered a lot of information on how to do the swap but I still have some questions on what to use and I need detailed answers. So these are my questions:
1. Will I be using the LS or Civic Radiator and Hose.
2. Can I use the LS Power Steering without modifying anything.
3. Will all vaccum hose plug up.
4. Will all of the civics motor mounts line up with the LS mounting brackets. (Im confused with this one, I read that you will have to use the stabilizer mount from the del sol if I want to put in A/C. What if I dont run A/C, will I be fine with the civic mounts or do I have to use the one from the del sol.)
5. Will the pipeing after the cat line up with my stock piping on the civic.
6. Is doing the B18B engine swap different from the B18A engine swap.
This is pretty much some of the questions that I have on my mind. Im pretty sure somewhere down the line I will get stuck somewhere and have to come back to ask a few more questions. Any comments or corrections will be greatly appreciated.
