How to get fast turn signals
Discussion in 'ECU's, Electronics, and Tuning' started by jtornado, Oct 7, 2007.
  1. jtornado
    jtornado New Member
    Minnesota
    I was wondering what wire do I cut or what do I do to get fast turn signals???
  2. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    I bought led lights (the kind that just replace the bulb and have like ten leds on them) for my turn signals once and they made my signals fast.
  3. jtornado
    jtornado New Member
    Minnesota
    Where could I get some led bulbs that will fit my socket?
  4. 91_civic_si
    Wasilla, Alaska
    What type bulb, mine were like 3057 dual filament. Please if you do this and they dont get faster dont blame me. It could have been they brand or something. I ordered mine off ebay but this was a few years ago. Just do a search for your bulb (### led bulb). If they dont make it faster blinking they will be hella bright.
  5. jtornado
    jtornado New Member
    Minnesota
    I was looking on ebay for those led bulbs and is it even worth getting them even if they dont make the blinker faster.
  6. 91_civic_si
    Wasilla, Alaska
    I got mine because they were clear leds that would light up orange for the front corner lights. Them blinking faster was just a surprise. I was not buying so they would blink faster just for the led technology. What year is your car? What type bulb? I have heard of cutting the ground wire on your turn lights but that sounds weird. The hyper led bulbs should make them blink faster but dont hold me to it.
  7. GSRCRXsi
    MD
    take out a bulb somewhere, and BAM fast signals. lol, but seriously, why? everyone will think you have a burned out bulb. plus its stupid annoying.
  8. nootrac22
    exeter pa
    I run my turn signals a 24psi, they blink hella fast
  9. klyph
    klyph Dismember VIP
    North Pole, AK
    Are you trying to speed it up because they are blinking too slowly, or do you just like fast blinkers?
    If they are too slow, you need to replace your flasher.
  10. mesodum
    mesodum New Member
    There is an actuator that activates turning signals you can either modify you existing one or order a jdm or euro one I belive inside is a spring that you can add tension to for a quicker response but I have never done this and the only car I've seen this done on was a 1986 Oldsmoblie Cutlass, but the actuator dose exist in you car
  11. boostedf22
    boostedf22 dis is why im not
    in the land of OZ
    double the fuse size !
  12. jtornado
    jtornado New Member
    Minnesota
    No my blinkers dont blink to slow, I just like the fast blinkers. I have a 92 civic si and I dont know my bulb size. Well if I take out my reverse light bulbs that dont even work anyway will that make my turn signals faster??
  13. eg6sir
  14. humblegumbo
    humblegumbo 1595cc's of Mad Fury
    CA
    Oh, wow, this thread almost caused my jaded soul to crack a smile on this cold leathery face.
    You can find LED turn signal lights at your favorite auto parts store. Usually they have a whole section just for ricers, I've seen these bulbs in there for probably ten bucks a pop, but sometimes they come in pairs.
    The main advantage to physically going to the store is that it will be so much easier to return them once you're tired of the effect in a day or two.
    So take out one reverse bulb & one turn signal bulb, & match them up inside the store. If you can't figure it out, there should be very friendly counter staff there to assist you. Replacing reverse lamps will allow you to see behind you when backing up. Replacing all four turn signal bulbs w/ LED's will make them blink stupid fast. Try just replacing just the fronts or just the rears.
    Of course, since this is a Japanese car, you will need to find a counter-clockwise metric torque wrench to remove & install the bulbs.
    [​IMG]:D
  15. 99sidude
    Ohio
    HOLY SHIT
    i am in tears laughing!!!!
    That site is amazing... made my day
  16. FObangah
    FObangah New Member
    Richmond VA
    flick the turn signal switch really fast. *clickaclickaclickaclickaclicka* They will blink hella-quick.
  17. jtornado
    jtornado New Member
    Minnesota
    lol alright you guys are giving me to much shit ill just leave it normal. forget it sorry I even lol. funny postings by the way.
    1 person likes this.
  18. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    you can just remove one of the bulbs from the blinkers.
    process of elimination.
    HYPER BLINKER ACTIVATE!!!
    It's annoying as shit to some drivers though.
  19. 99sidude
    Ohio
    gotta give him credit for being a good sport about it
  20. humblegumbo
    CA
    Credit given.
    And as smart assy as I was in my previous post, it's still a legit how-to. I discovered this by trying to put LED's in my car.
    Couldn't stand the fast blink & not worth it to buy the special flasher....
