how to recognise ecus
Discussion in 'ECU's, Electronics, and Tuning' started by gatto-is-alive, Mar 5, 2009.
  1. gatto-is-alive
    gatto-is-alive New Member
    EARTH
    i have a b16a 2nd gen 92' model how can i know which ecu i have installed
    any pics can help 10x;)
  2. get_nick
    Washington State
    google: "honda ecu"
    there is a sticker on the side.
  3. gatto-is-alive
    EARTH
    do you have any pics or just a link pls?
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  5. Briansol
    look for the 3 digit code on the upc..
    xxxxxxx-XXX-xxxxxxxxx
    the middle is what it goes by
  6. gatto-is-alive
    EARTH
    ok i took out the engine from a 93 jdm integra xsi and i can see that the ecu is an obd1 and mine has (pr3) printed on the lable
    so can this ecu be chipped for the turbo mod?
  7. get_nick
    Washington State
    yes, you can use it to tune for turbo.
  8. gatto-is-alive
    EARTH
    any suggestins about which chips to use ?:confused:
  9. get_nick
    Washington State
    it's personal preference.
    a lot of people like chrome or hondata. i think someone gave you a link to one in your other thread.
  10. gatto-is-alive
    EARTH
    heres a stupid question, the crome chip is that eprom that get swapped in the ecu ?
  11. sloefdud
    sloefdud New Member
    nashville,tn
    chrome would be the best . and if you took that motor out of the xsi what did you do with the shell. that motor is worth 3000. i had one in my old ef and loved it better. and you might want to check the trans tag and see if it is one that has lsd. mine did and it was so fun driving in the snow. very hard to find swap. i would trade my gsr for it in no time.
  12. gatto-is-alive
    EARTH
    i bought it as a JDM half cut and got rid of all the rests! and mine has no lsd it is a cable trans
  13. get_nick
    Washington State
    some cable trannys came with lsd.
  14. gatto-is-alive
    EARTH
    mine is the ys1 i don't think it is an lsd model
  15. AHHVTEC
    Alabama
    ys1 came both ways
  16. gatto-is-alive
    EARTH
    ok i'm confused when i do a burout the two wheels do turn but the left wheel spin faster then the right ????
  17. AHHVTEC
    Alabama
    well if you want to know for dead sure pull the axles out and if you can see all the way through the hole its a lsd if there is a bar there its non lsd
  18. gatto-is-alive
    EARTH
    can someone tell me how much cc are the stock b16 injectors
  19. gatto-is-alive
    EARTH
    if i buy a chipping kit from ebay for my ecu will it be good enough to tune?
  20. gatto-is-alive
    EARTH
    i live in MALTA and here is very difficult to tune cars so I NEED SERIOUS HELP!!!!
