i need some tuips!
Discussion in 'Other Vehicle Discussions' started by teamBattleTek, Mar 22, 2007.
  1. teamBattleTek
    teamBattleTek New Member
    dO ANYBODY KNOWS HOW TO TAKE OUT A TIMEING BELT OFF A B18C GSR WITH THE CAM GEERS OUT? i NEED TO TAKE OUT THE PULLY BUT i GOT NOTHING TO HOLD THE CRANKSHAFT IN PLACE.
  2. reikoshea
    Dallas, TX
    ive only done a timing belt 2 ways on a honda.
    a) use the timing belt tool (you can get it from honda or snap on, but both are WAY too expensive).
    b) use an impact and pray.
    usually b takes some time cause that nut never wants to come off, and then when it finally does come off.....how are you going to get it back to the right torque.......thats the question that has plagued back yard honda freaks for years.
    my advice is go to the dealership and buy the tool if you want it done right (i even broke down and did it).
  3. hosmer
    B R I D G E W A T E R
    -wow
    theres also a hole in the tranny where you can see the flywheel...have someone bind it up with a prybar and hit the crank bolt with a big fuckin pipe on your breaker bar (last resort)
    go easy or you'll snap the bolt (fucked)
    -heat it up if you can
  4. Celerity
    Celerity Well-Known Member
    Impact is the only way. You use pry bars and you'll break the pulley more than you'll get that bolt out.
  5. TurboMirage
    feed hemp rope into the #1 cylinder during the compression stroke.
  6. Celerity
    That's complete shit man.
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    No way in hell I'd try the "rope" trick.
    Impact ftw.
  8. klyph
    klyph Dismember VIP
    North Pole, AK
    If you smoke the rope first, you might believe it works :shrug:
  9. hosmer
    put a breaker bar with the socket on the crank bolt and position the bar so it is to the left of the pulley and resting on the ground
    then, try to start the car
  10. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    i would love to see someone actually try that :lol:
  11. TheManRSW
    TheManRSW TheManRSW
    Turning the car over with a breaking bar on it will not work with Hondas...it will actually tighten the bolt or break it (works on chevys though). Your best bet is to use the tool from Honda or snap-on...that's why they make them.
