internals
Discussion in 'Forced Induction' started by Rickd16, Dec 13, 2006.
  1. Rickd16
    Rickd16 New Member
    Chicago, IL
    i got a 1992 civic wit a d16 in it. wat internals do i need to make it turbo ready?
  2. turb2o_vtec
    turb2o_vtec New Member
    If you got the money forge piston (low compression like 9:0:1) and connecting rods. If not the some vitara piston with tunertoys rod suit well for the budget. It's proven over 400 hp already on vitara piston. Don't forget to notch your block too if using H-beam rods.
  3. TunerToys
    TunerToys Junior Member
    Thanks for the TunerToys love, and some good advice there.
    Making it turbo ready, depends on how much HP you want to make. If you have relatively low HP goals, you can probably get away with stock internals (under 10 psi). If you have higher goals, you'll need to buy accordingly. Like turb2o says, there are folks making 400Hp on Vitaras.
    It just takes some plannning and research. Figure out what you have to spend on the project, and then figure out how to spend the monney properly. Nothing sucks more than getting halfway into to a project, and have to stop because of money concerns.
    Craig
  4. Rickd16
    Rickd16 New Member
    Chicago, IL
    I'm swaping in a d15b vetch in it, so i'm looking to get 250whp out of it
  5. TunerToys
    So I'm not completely sure on this, but I believe that you may have trouble finding cheap connecting rods for the D15 engines, which may limit you on the internal upgrades you can run. I don't know for certain about the D15B VTEC motors, but do know that the D15B7 cranks have smaller journals, and that there are only one or two companies that make rods for them, at about $700 a set.
    Hopefully there are some guys who can post up stronger info about the D15B VTEC motor, and tell us if I am right or wrong.
    If the $700 figure is not a problem for you, then for 250Hp, I would suggest rods and pistons as the only real changes you need for the engine internals. Add a Cometic gasket and ARP headstuds, and that would be it.
    Craig
  6. Rickd16
    Rickd16 New Member
    Chicago, IL
    thanks for the response, i've been doing researh for parts for the d15b but i cant find anything. any suggestions?
  7. turb2o_vtec
    I believe there are some people on d-series.org that is running the d15b vtec with vitara piston and tunertoys rods. Check that site out. They should be able to help you out. It not there is also turbod16.com.
  8. Rickd16
    Rickd16 New Member
    Chicago, IL
    what turbo would be best for my d15b?
  9. gettocrx
    gettocrx Member
    Honolulu, HI
    Try a t3/t04e .57 compressor with a .48 or .63 ar turbine.. Most people say go with the .63 but I kinda like my .48 on the sohc!
  10. Rickd16
    Rickd16 New Member
    Chicago, IL
    how much horse power can i get out of it with a .63 turbine?
