Ipod Question
Discussion in 'Computers, Games, Electronics etc' started by 90 accord, Nov 23, 2009.
  1. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    so, i've been having issues with my ipod sound levels.. whenever i play music, some songs play way loud, while others are so quite you can barely hear them.. is there a way to normalize the volume at all?
    i have touch, if it matters
  2. Drake
    Drake Well-Known Member VIP
    It may have to do with the 'sources' of your music..... Unless you buy everything from iTunes. Now, there may be a conversion program or something along those lines that will let you do a batch job and equalize them out.
  3. BigJ
    On my iphone there is an option to make it so that it levels the sound across songs.
  4. 90 accord
    Mesa, AZ
    whats the option called? i see one called sound check, but it doesnt have a description
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    My Nano has this feature. Look for "Sound check", and turn it on. By default I believe it's turned off.
    Edit: noticed I was a little late. Anyways, it gives you a description in iTunes.
  6. 90 accord
    Mesa, AZ
    awsome, thanks! hopefully i wont have to mess with the volume on my dock every time the song changes!
  7. totalburnout
    NJ
    You can change the songs via iTunes.
    Under Edit -> Preferences - > Playback -> Sound Check.
  8. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    If you want a more technical solution, there is an app called mp3gain that will scan your files and normalize them all to a volume you specify.
  9. SlushboxTeggy
    New Jersey
    Yup. You can do it for free in iTunes.
  10. Battle Pope
    As far as I know, Itunes doesn't change the volume level on the MP3 file itself, just normalizes it on the itunes front-end.
    I should note that MP3gain is freeware, easily located via google.
  11. SlushboxTeggy
    New Jersey
    Not sure how I did it, but I had the same problem, clicked around on iTunes, and now they all play at the same level. Before I could barely hear one, then the next would deafen me.
