LS.. (CHOKING) an it turns off!!
Discussion in 'Civic and del Sol - EG and EK' started by terry, Aug 8, 2008.
  1. terry
    terry New Member
    :confused:i got an ls an wen im drivin an i stop it sounds like it wants to turn off like its choking or something an then 3 seconds later it does an wen i turn it on if i dun rev it it turns off so i have to keep the pedal pushed all the time cause if i let it go it turns off its gettin me kinda mad now an i dun kno wat it is at first i thought it was the gas buh the tanks full so wat kan it be?
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    possible vacuum leak, check all your hoses, any cels?
  3. terry
    terry New Member
    naw its not leakin anything i alredy checked it here since my motor mounts are messed up my trannys like relly loose so kould that be it that everything like not in its place??
  4. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
    bump for having the same problem i do...:(
  5. sernmd
    sernmd New Member
    fuel filter, spark plugs-wires-rotor-cap, dirty injectors, iac-valve, timing, shitty gas water in the tank.... try all of those to start
    1 person likes this.
  6. greddy_ek9
    greddy_ek9 New Member
    bump here 2 same problem
  7. NWDRVRBWE
    NWDRVRBWE Hands Off my Balls
    kentucky
    What year + model is your ls?
