my B16 won't start
Discussion in 'HYBRID -> EG-EK / DC' started by LowBudgetRacer, Aug 2, 2003.
  1. LowBudgetRacer
    LowBudgetRacer Junior Member
    man did my swap, everything is in its spot, keys in, it cranks but the motor won't start!!! changed coil inside distributor, changed rotors, module, everything except cap because caps looks good, and still no sparks.. what kan be wrong?!? kan it be the wiring harness.. this ever happens to anyone before??? please help.. thx
  2. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    I'd say check your wiring, if you didn't get the right wire to the right injector that could be screwing you up. or if your plug wires are going to the wrong plug
    those would be my best guesses
    good luck
  3. sih8tch
    sih8tch Junior Member
    check your ECU fuse. that xiet happened to me before.
  4. LowBudgetRacer
    i checked the fuse already, fuse all look good, dunno bout the injector harness, but then the thing is we have no sparks coming from the distributor to the spark plugs wire...
  5. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    make sure that the swap has spark plugs in it. Does it sound like that motor has compression in it? or does it just almost whistle like? and make sure that you let the fuel pump get the gas to the motor. turn the car to the on position without starting it (30 sec.) and let the fuel pump get some gas into the lines.
    Darin
  6. gyallis
    gyallis Senior Member
    Bronx NY
    Also check the distributor, it doesn't hurt to redo it. Can't remeber the name of the part put theres something to turn in the right direction, clockwise or counter. A manual would also help.
  7. LowBudgetRacer
    no spark from wire, u know how when u pull one plug out from distributor, u leave it near there and crank, theres no sparks... thats what im trying to see.. kan injector wires mess with sparking?
  8. RS1
    RS1 Junior Member
    ok im with lowbudget, the deal is theres power going inside the distrubuter but none coming out, can that be the distrubuter or the wire harness, we tried changing everything from distrubutor except cap, thanks fellas
  9. LowBudgetRacer
    exactly with mynes, power going through, but no power coming out from distributor to spark...
  10. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ok you dont pull the wire from the cap you pull it off the plug and use and old plug with the end touching a ground and then check for a spark
  11. 97CTR
    97CTR Senior Member
    yeah were you grounding your plugs when checking for spark?
  12. highperboi
    highperboi Senior Member
    Alameda, California
    he has a OBD0 engine and hes useing a OBD1 harness does that work???
  13. LowBudgetRacer
    motor starts and run, but the thing is now is that low rpm, car lags, huffing and puffing till it get to 3000rpm, after that, car pulls like krazy.. what could be the problem
  14. pissedoffsol
    what ecu are you using?
    what obd distributor are you using?
    what b16 motor is this on?
    what car is this in?
    it helps if you give us all the info.
    and for christs sake, there is no FUCKING K in CAN. :emofo:
  15. Iquark
    Iquark Senior Member
    Mount Vernon, WA
    The lag at the low end sounds like a fuel problem to me... Sound right to everyone else?
  16. word
    word Senior Member
    o2 sensors??
    sounsd like the problem i am having right now
