Cashizslick
!i!i!i!i!i!i!i!i!i!i!i!
Im going to a startup in jan and the owner wanted me to get the tech all setup on a 57in x 17in bench from crate.
Below are the results - took me 2 tries because I wanted it to look as clean as possible.
The only thing left is for the flat mounted monitor to be installed & plugged in. Theres just enough room on the power strip for it. Everything is wired into our network and the epson doubles as a scanner and fax.
UPDATE:
Heres the end result
UPDATE:
