LudeBoy
Slave to the EF
Larger turbine = more surface area = more air pushed per PSI.
Your not getting it, if more air were pushed there would be more psi.
I think he is talking about air flow, not psi. what most people here are tying to explain, is that if you fill a 20onz bottle at 10psi and a 55gal tank at 10 psi. The 55gal contains way more air than the soda bottle. In the engine is the same. Why do you think drag cars use huge turbos? At high RPMs the small turbo will not give enough volume of air to maintain the set PSI. The more air the engine consumes the more air the turbo has to "push" to keep up with the set psi. That said, I would be more concerned about turbo efficiency more that jut a random psi. If you have a turbo too small for the air flow of your engine at a set RPM, then the turbo becomes a restriction in the system regardless of air pressure.On the other hand if your engine is small and you are not going to rev it up to the moon a huge turbo will lag too much for a small restricted engine.Your not getting it, if more air were pushed there would be more psi.
amen to that brother...Which is also why I say that horsepower is the best judge of what turbo you wan to run and how you build your engine to handle it.
No dude, you're not getting it.
edit:
Ok, I'll go ahead and try to explain this again.
It's all about CFM and a larger turbine moves more CFM at any given boost level than a smaller one.
What to run 20psi? That's great, are you going to be running that with a tiny turbo or a behemoth one? The power outputs will be drastically different as will the wear on the engine.
With a larger turbo there's more air compressed so there's a larger volume of air coming thru at 10 psi than from a small turbo and more air = more power, which makes sense because there's more air to push so it takes longer to push it which is why large turbos take longer to spool up. Am I comprehending right Blanco?
A large water wheel at a watermill moves more water than a smaller one while moving at the same speed, right? Right. Same principle. The turbine drives the compressor wheel, which pushes a given CFM into the engine. I never said that exhaust gas didn't have to drive the turbine. I said that a larger turbo pushes more CFM at a given PSI than a smaller one, which is true. It's a dynamic system, not a static one, just like everything else that has to do with how an engine actually works. If we were talking about tanks for oxy-acetylene welding, which are static, then yes 10psi will be 10psi regardless of what size the tank is.
Re-reading that post, I should've said compressor wheel instead of turbine. My full attention wasn't on the post, my bad.
At any rate, I'm done with this topic. A T25 at 10psi is putting out the exact same amount of air (CFM) as a GT45R at 10psi, if that's what you really want to believe.
