NQO'TD - Noob Question O'The Day
Discussion in 'Civic and del Sol - EG and EK' started by nplsdvr, Jul 12, 2008.
  1. nplsdvr
    nplsdvr New Member
    B'ham, AL
    I've got a '98 civic Ex...so what are the EG and EK designations?
    Thanks!
  2. klyph
    klyph Dismember VIP
    North Pole, AK
  3. nplsdvr
    nplsdvr New Member
    B'ham, AL
    Gotcha! Thanks!
    The other thing I stumbled across was "Chassis Codes"
    What is the significance of a chassis code and how would I use that info to my advantage?
    Thanks again!
  4. phunky.buddha
    Dallas / Fort Worth, TX
    The "EG" and "EK" are the chassis codes. The two letters are followed by a number, and with those 3 digits, you can find out quite a bit about what a car is and how it was setup from the factory.
    The EG8 is the USDM 92-95 Civic sedan.
    The EG6 is the JDM 92-95 Civic SiR hatch.
    AP1 = 2000-2003 S2000
    AP2 = 2004+ S2000
    Stuff like that.
  5. eg6sir
    a 98 EX is an EJ8
  6. nplsdvr
    nplsdvr New Member
    B'ham, AL
    What would be a "for instance" on what I would use that info for? I would need the info from the chassis code if I were doing (fill in the blank).
    Thanks!
  7. BrutalB83
    Rochester Hills, MI
    It's just a piece of information that's part of a Honda's VIN. You can use it to help identify a certain car, or to refer to a certain body style. I don't really understand what you're asking for here...
  8. nplsdvr
    nplsdvr New Member
    B'ham, AL
    I'm not exactly sure what I'm asking either! :)
    When would I find the chassis code valuable? For ordering parts? For checking engine swap possibilities?
    If someone says "it's an EG8", that tells me....what?
    Still clear as mud?
  9. SlushboxTeggy
    NJ to MA to CA
    I'd like to point out that on here we really only use codes like EG, EK, DC, etc. Like it was pointed out before a 98 EX is actually an EJ. And while DC generally refers to a 3rd generation Integra, a 4-door is actually a DB. And a RSX is technically a DC5, even though an RSX is a fourth gen. Integra.
    But to answer your question, a chassis code tells you exactly that. What model the car is, and what trim the car is. Example: DC2= DC tells you it is a 2 door, 3rd gen., Integra. And the 2 designates the trim. In this case, Type R.
  10. BrutalB83
    Rochester Hills, MI
    They don't really have any other use besides just as a quick method of identifying various Honda vehicles. Very rarely would you use them when ordering parts. Most often it will just list something like "92-95 Civic EX coupe" or on order forms rather then using the chassis codes...
  11. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its all hard to take in at once like for example the 1992 body style civic as we know it started with that body style in japan in 1991 same goes for all there cars there all a year behind us
  12. nplsdvr
    nplsdvr New Member
    B'ham, AL
    Thanks for all the info and clarifying it for me.
    'preciate it!
    nplsdvr
  13. phunky.buddha
    Not really- they just call their cars' model years by the year they were made, not the next year like we do. 1992 model year cars started selling in 1991 in the US- they're just called 92s. In Japan they would still be 91s.
  14. awptickes
    MD
    Yeah, in europe it's the same way. By that logic, my car is a 99. The american registration says 2000 though...
  15. AHHVTEC
    Alabama
  16. oneofakinduserid
    oneofakinduserid Eh?
    Mebane, NC
    JDM and USDM Civic Chassis Codes
    Chassis - Motor - OriginYear - Vehicle
    4G (1988-1991)
    ED3 - 1.5L - USDM - All4-door DX/LX
    ED4 - 1.6L - USDM - All - 4-door EX
    ED6 - 1.5L - USDM - All - 3-door Standard
    ED7 - 1.6L - USDM - All - 3-door Si
    ED8 - 1.5L - USDM - All - CRX standard / HF
    ED9 - 1.6L - USDM - All - CRX Si
    EE2 - 1.5L - USDM - All - Wagon
    EE4 - 1.6L - USDM - All - Wagon 4WD
    EE8 - B16A - EDM - All - Civic VTi
    EF1 - D13B - JDM - All - Civic 3-door/4-door
    EF2 - D15B - JDM - All - Civic 3-door/4-door
    EF3 - ZC - JDM - All - Civic Si 3-door/Civic Si Extra 3-door
    EF5 - ? - JDM - All - Civic 4-door 4wd
    EF6 - D15B - JDM - All - Civic ? / CR-X
    EF7 - ZC - JDM - All - Civic ? / CR-X Si
    EF8 - B16A - JDM - All - CR-X SiR
    EF9 - B16A - JDM - All = Civic SiR
    5G (1992-1995)
    EG1 - D15B - JDM - All - 3-door/4-door/CR-X
    EG1 - D15B7 - USDM - 1993-1995 - del Sol S
    EG2 - B16A - JDM - All - 3-door/4-door/CR-X
    EG2 - B16A3 - USDM - 1994-1995 - del Sol VTEC (DOHC)
    EG3 - D13B - JDM - All - 3-door/4-door
    EG4 - D15B - JDM - All - 3-door/4-door/CR-X
    EG5 -D16Z6 - EDM - All - 3-door/4-door
    EG6 - B16A - JDM - All - 3-door/4-door/CR-X
    EG7 - D13B - JDM - All - 3-door/4-door
    EG8 - D15B - JDM - All - 3-door/4-door/CR-X
    EG8 - D15B7 - USDM - All - 4-door DX/LX
    EG9 - B16A - JDM - All - 3-door/4-door/del Sol CR-X
    EH1 - ZC - JDM - All - 4-door/4WD
    EH2 - D15B8/D15Z1/D15B7 - USDM - All3-door CX/VX/DX
    EH3 - D16Z6 - USDM - 1993-1995 - 3-door Si
    EH6 - D16Z6 - USDM - 1993-1995 - del Sol Si
    EH9 - D16Z6 - USDM - All - 4-door EX
    EJ1 - D16Z6 - USDM - All - 2-door EX
    EJ2 - D15Z1 - USDM - All - 2-door DX
    6G (1996-2000)
    EG1 - D16Y7 - USDM - 1996-1997 - del Sol S (SOHC)
    EG2 - B16A2 - USDM - 1996-1997 - del Sol VTEC (DOHC)
    EH6 - D16Y8 - USDM - 1993-1995 - del Sol Si (SOHC)
    EJ1 - D16A - JDM - All - 2-doorEJ3?JDMAll2-door / 4WD
    EJ6 - D16Y7 - CANADA - All - 2-door DX/Si
    EJ6 - D17A7 - CANADA - 2000 - 2-door DX-G/ 3-door CX-G
    EJ6 - D16Y7 - CANADA - 1996-1998 - 3-door CX
    EJ6 - D16Y7 - CANADA - 1999-2000 - 3-door CX/DX
    EJ6 - D16Y7 - CANADA - 2000 - 3-door SE
    EJ6 - D16Y7 - CANADA - All - 4-door LX/EX
    EJ6 - D16Y7 - USDM - All - 3-door CX/DX
    EJ6 - D16Y7 - USDM - All - 4-door DX/LX
    EJ6 - D16Y7 - USDM - 1999 - 4-door DX-V
    EJ7 - D16Y5 - USDM - All - 2-door HX (VTEC-E)
    EJ8 - D16Y8 - CANADA - All - 2-door EX
    EJ8 - D16Y8 - USDM - All - 2-door/4-door EX
    EK2 - D13B - JDM - All - 3-door/4-door
    EK3 - D15B - JDM - All - 3-door/4-door
    EK4 - B16A - JDM - All - 3-door/4-door
    EK5 - D16A - JDM - All - 4-door 4WD/LEV
    EK8 - D16A - JDM - All - 4-door 4WD/LEV
    EK9 - B16B - JDM - All - 3-door Type-R
    EM1 - B16A2 - CANADA - 1999-2000 - 2-door SiR
    EM1 - B16A2 - USDM1999-20002-door Si
    7G (2001+)
    ? - 1.7LUSDM - All - 2-door DX/LX
    ? - 1.7LUSDMAll4-door DX/LX
    ? - 1.7LUSDMAll2-door HX
    EM2 - D17A1 - USDM - All - 2-door/4-door EX
    EP1 - 1.4L - JDM - All - 3-door
    EP2 - 16L - JDM - All - 3-door
    EP3 - K20A3 - USDM - 2002+ - 3-door Si
    EP3 - K20C1 - JDM - All - 3-door Type-R
    EU7 - 1.4L- JDM - All - 5-door
    EU8 - 1.6L - JDM - All - 5-door
    Knowing that code can make it easier for you to find out things about your car. Also, some things that will fit one chassis wont fit on another chassis of the same year. For example, the headlights on a 93 civic sedan (EG8) wont fit on a 2 door civic of the same year (EJ2). If i'm wrong someone will correct me I'm sure.
  17. phunky.buddha
    You're wrong. :) The headlights are the same- the corner lenses (which are separate) are what's different.
