power shifting?
Discussion in 'Racing and Driving Techniques' started by lonelydriver, Jun 13, 2004.
Thread Status:
Not open for further replies.
  1. lonelydriver
    lonelydriver Member
    ok, so my cousin keeps bitching to me about "power shifting" has anyone heard of it? he claims you use it mainly for drag racing, 1/4mile... he wont explain it to me and tells me that he'll show me it when i go visit him later this month.
    is he right about "power shifting" ? or should i tell him hes an idiot and whatever "power shifting" is, it's just messing up his clutch/tranny... whatever... etc
    thanks everyone.
  2. highperboi
    highperboi Senior Member
    Alameda, California
    it is when you shift but dont let the gas off. i do it sometimes i dont know if it is bad or not.
  3. jamesA
    if you don't let off the gas it'll keep your rpms up and unless you can do it quick enough you'll end up bouncing off the rev limiter. It's not going to hurt you that bad to take your foot off the gas for that split second of slamming it into 2nd or 3rd.
  4. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    It is retarded, does you no good, and damages your clutch and tranny. DON"T DO IT: Its for Ricers.
  5. Projectzc
    Projectzc Senior Member
    Power shifting is cool. I have the tee shirt there my fav band. Their dreamy.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    yea.
    you will lose traction if you let it rev up. this technique will work on awd cars, since they got all the straight line traction, but even for them it damages the tranny.
  7. lonelydriver
    lonelydriver Member
    haha, that's probably why he thinks he's going faster, because he loses traction and his wheels spin.
    thanks for the quick replies. i'll make sure to link this thread to him, lol.
  8. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Just tell him that everyone on Hondaswap thinks he is a ricer. HA. :D I bet he talks about granny shifting too?
  9. Citizen_Insane
    Minneapolis
    Yeah, power shifting in an AWD car is a REALLY bad idea. AWD systems are actually quite weak, and they are prone to lots of problems. Take Subaru, they only make AWD cars and my center diff. went out 2 times in a car that was NEVER driven hard. You really have to baby most AWD cars or you'll end up with lots of problems.
  10. nismogod
    nismogod Senior Member
    Deltona, FL
    did you know that you can't "power shift" a lotus Esprit? well, according to the dude that owns a the coffee shop you can't <he has also owned 3 lotus (loti?)> i was under the impression that powershifting meant no clutch. but i guess i'm wrong. whats it called when you do clutches shifts? aside from being called an automatic. lol.
  11. Citizen_Insane
    Minneapolis
    um....clutchless shifting? Thats the only thing I've heard it called. I duno if its bad to do, but its kind fun once in a while.
  12. foolish
    foolish Member
    clutchless shifting is called slam shifting and thats about a milloin times worst then power shifting.
  13. nismogod
    Deltona, FL
    if it breaks build it better next time? it always my excuse to upgrade. lol
  14. Citizen_Insane
    Minneapolis
    Um...I don't do anything that "slams" when I clutchless shift. I just pull the car out of gear, wait for the revs to drop, and the quick pop it into the next gear. I don't grind it or anything at all, it just slips into gear when you reach the correct rpm.
  15. ahedau
    ahedau Senior Member
    Middle GA
    shifting w/out the clutch is called "rev matching".. you match the revolution of the engine to what it will be for that particular gear. When done correctly, it slides into gear w/ no grinding or ill effects on the tranny. However, it ain't easy to do correctly
  16. webink_EK9
    webink_EK9 Senior Member
    Rev matching is when you're down shifting and you tap your gas to bump your rpms higher to match the lower gear. Do it a lot in road races.
  17. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Jesus, whatever happened to just learning how to actually drive? All these techniques will just happen if you practice and figure out what the best techinque is for each scenerio. What works for one, doesn't nescessarily work for you. The powershifting your cousin is refering to is retarded. I wouldn't try it unless you have an ECU that can hold XXXXrpm during the shift.
  18. ovcrash
    ovcrash Senior Member
    Quebec, Canada
    Sorry! but i don't think so. when you drive a semi that's how you shift trough gears. So i don't think it's bad!
    But for "Power Shifting" i think that's a old technic used on old muscle cars?? I never heard a guy driving a Jap Car talk about "power shift", i mostly heard drivers of muscle cars talk about that..anyways..
  19. CRX-YEM
    Wallingford, CT
    power shifting is very common with mustangs, specifically with a nice T5 transmission, the tranny has very well matched gear ratio's and full synchro's
    If you're after a few 10th's of a second in a 1/4 this is a good techniques to learn. it really only works well with a similar setup like the ford T5 transmission
    Shifting with out the clutch I used to do all the time in my old suby 85 GL hatch. you've really got to know your shift points and the feel of your transmission as not to fuck anything up. and semi's can do this easily becausse the transmission are designed 100% different than a car or light truck.
    What would be more appropriate to quicken a shift is the use of a sequential shift transmission
  20. allbottledup
    allbottledup Senior Member
    Galloway, NJ
    I read on hondatas website one of the upgrades that they have is a full throttle shift. It puts a rev limiter on it so that you can keep your foot pegged to the floor while you shift. Watch the video its pretty cool.
Thread Status:
