you have to remove that spring in order to flip up the caliper to replace the pads, just unbolt the ebrake cable and use some pylers to remove the spring. good luck
Yep. There is also a drum brake spring tool you can get to install and remove the springs. Should be able to find one at like Auto Zone ect. Pliers or vice grips will also work, that is how I did them before I got the tool.
