rev lim kicks in at 3500
Discussion in 'Civic and CRX - EF' started by branded noooob, Dec 25, 2008.
  1. branded noooob
    branded noooob New Member
    jackson missouri
    k,heres the deal i got to foolin around w/my car which has a gsr in it,and i messed w/somethin,can anyone give me a general idea of what causes this...plz im open to any ideas/help...thanx..j
  2. efhondakid
    Akron-Canton, Ohio
    Well did it do this before you "messed" with stuff? And what exactly did you "mess" with. The ECU may have went into limp mode, causing the 3.5K rev limiter.
  3. MthaFuknGreen
    Lodi, CA
    why dont you just unmess what you messed with?
  4. branded noooob
    jackson missouri
    not to sure what i did,im just curious as to what may cause this
  5. MthaFuknGreen
    Lodi, CA
    whatever you messed with..
  6. branded noooob
    jackson missouri
    it idles just fine its just when i hit the gas and it revs to 3500,the rev lim kiks in..
  7. efhondakid
    Akron-Canton, Ohio
    The ECU is in limp mode. There is a blue two prong connecter tucked up by the passenger side kick panel, jump the connections with a paper clip or a piece of wire. Turn the key on and count the flashes of the CEL. Start there that should give you an idea of where to start.
    1 person likes this.
  8. branded noooob
    jackson missouri
    i did the paper clip and i cant even get it throw a code or even bink a thing ,its already on because of an o2 sensor,from past checking
  9. branded noooob
    jackson missouri
    hey guys dont leave me hangin here,i got a problem...
  10. efhondakid
    Akron-Canton, Ohio
    Well if you could tell us what you did to fuck it all up and to pull the codes, not much more I can tell you We need a little background on the problem. :dunno:
  11. branded noooob
    jackson missouri
    i think the fricken joker that put the vtec controller in and had the car previouslydid a qwak job of it,because i think it started after i taped up the wires because it was just some dangling crap in there,sh!t should be soudered and or plugged together not spliced,i wanted to take the piece of crap out but its got a center console fabbed for it,those things are known to screw somethin up if not installed w/some common sense...lol,i just hope i didnt fry the ecu,i was just hoping that someone had had this issue and maybe it was somethin else ...just my luck...lol
  12. bjoebright14
    bjoebright14 New Member
    efhondakid o got a question
  13. stevennn09
    stevennn09 Member
    Ohio
  14. bjoebright14
    the two prong wire that is by the passenger kick panel he was talking about jumping what does it go too?also what does it do?
  15. MthaFuknGreen
    Lodi, CA
    you touch the two ends together so you can flash the ecu and get a code.
  16. bjoebright14
    does it not plug into anything?mine flashes a code.im just tryimg to understand lol.
  17. MthaFuknGreen
    Lodi, CA
    yeah, its all a learning process.
    but no, it plugs into nothing.
    its sole purpose is to touch the two prongs together with some metal so you can get a code if for some reason they arent flashing.
  18. bjoebright14
    ok so i must be looking at the wrong thing.have you happen to read my other thread i posted about my car?
  19. MthaFuknGreen
    Lodi, CA
    ive posted in all your threads, so yeah.
  20. branded noooob
    jackson missouri
    i did that as i already knew,but strangely it does not a thing...no blinks at all it just stays on ,i think maybe my ecu is starwars...piggy backs suck!
