Rywire Vtec harness
Discussion in 'ECU's, Electronics, and Tuning' started by 93civicracer, Jan 12, 2008.
  1. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    I want to wire up vtec in my jdm d15b vtec swapped dx, it's a 93 dx and I was wondering if this harness will work. It's for a dx to d16z6 but I'm not sure if it'll work with a jdm d15b, anyone know for sure?
  2. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Not too sure you should just hit up Rywire and ask them directly. Rywire is awesome they will take care of you.
  3. haao13
    haao13 New Member
    PA
    or you could just run the two wires yourself and save a little money :)
  4. popeye
    popeye Banned
    Altoona, Ps
    solenoid (one wire plug) - A4
    Pressure switch - D6
    Pressure switch ground - A26 (or can be grounded to the head)
  5. BrutalB83
    Rochester Hills, MI
    Yes, that's exactly what you need.
    True, but then again, how much money is he really gonna save? The harness is only $40. He'd have to pay for wires anyway to do it himself. To me, it's worth it for a nice, clean, easy install.
  6. integraslut78
    KiLLa kALi
    I was saying to ask Rywire if it will work before you buy it not to have them wire it for you. You would have to drive a long way for them to wire it for you, by the way their wire tuck jobs are unreal clean.
  7. BrutalB83
    Rochester Hills, MI
    I don't think he was suggesting that Rywire actually install it for him, he was just saying to skip buying the pre-made wiring and just wire it up himself. And my response to that was: the Rywire harness is only $40, and it makes for an easy and clean install, so why not buy it?
  8. integraslut78
    KiLLa kALi
    Werd I fully agree with you.
  9. 93civicracer
    Texas
    Great thanks for the responses. Just gotta check the timing, fix the coolant and engine oil leaks, clear the ecu codes, put in some suspension bolts I left out when I did the swap and then I'll be buying the harness and wiring up vtec. lol
  10. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    JESUS H. CRIMONY!! buy the harness from rywire..simple plug and play. yea you can do it a lil cheaper yourself but its worth the money trust me. simple..simple..simple.. my d15b's vtec works flawless! wires will be there already..,just match the colors..and bam! wired up that vtec yo!!
