seat help
Discussion in 'Civic and CRX - EF' started by quadboy2002, Jun 26, 2007.
  1. quadboy2002
    quadboy2002 fed-town racer
    washington
    i got some front seats from an ek civic and i wanna put them in my ef how the hell do i get them to work or is it even possible
  2. invisibledemon
    Tn
    im not positive but they may just bolt right in, if not then you need to take the mounts off of your ef seats and put them on the ek seats, just like if you were to buy a aftermarket seat.
  3. SHOGUNOVDDRK
    SHOGUNOVDDRK New Member
    australia
    yeah he is on the ball about this....
    you just have to adapt your bases and sliders to the seats
    or use your bases with the ek sliders
    or use the whole ek setup and drill new holes and nut/bolt them in(like aftermarket seats as invisible said)
    but before you go do any work take the ef seats out and sit the ek seats in just to see how the height is....;)
  4. quadboy2002
    washington
    i put the seats in and they sit to high and the bolt patterns a little off and the mount setup is diffrent from my seat to the ek seats maby i should just buy racing seats
  5. SHOGUNOVDDRK
    australia
    ok well that wasnt too much for a supprise...^_^
    as i explained above you will need to splice the mount setup...
    but did you sit the seat in with the ek mount setup or just the seat in?
    and before you go spending hundred of dollars on racing seats perhaps you should look for some alternatives :mellow:
    see the good thing about honda's are that there so compatible so if you go hunt for some seats of the same years as your ef then you may be able to find a better fit...not quiet as sexy as the ek seats but still a nice alternative
    and just for a forenote next time you wana start a new topic you may just want to use the search function
    (my seat question)
    http://hondaswap.com/civic-crx-ew/seats-88491/
  6. invisibledemon
    Tn
    swap the brackets. the whole assembly from one seat to another. your ef brackets sit lower than the ek brackets, thats the main reason the seats sit high.
  7. quadboy2002
    washington
    uh yea i cant swap the bases on the seats the ef seats have one side that bolts to the bottom of the seat and the other side bolts on the side and on the ek seats both bases bolt on the side
  8. invisibledemon
    Tn
    can you swap just the slider part of the seats?
  9. quadboy2002
    washington
    i dunno how to get the damn sliders off and im not sure they will fit prolly gonna get racing seats they look sweet plus i know i can get them to fit
