wow someone that I can help out! yes! muhahaha I think your o2 sensor on your vx is 5 wires and need to convert it to 4 wire to plug into your motor.? Not sure but ok pissedofsol will help you! he helped me
that sucka will drop right in but you'll need the ECU and have to convert to 4 wire o2 sensor. your hatch is already wired for vtec so it should be a really easy swap as far as swaps go. B)
