T25 Wastegate PSI setting...
Discussion in 'Forced Induction' started by knowledge, Dec 18, 2002.
  1. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Those 2 "things" as you refer to are the wastegate actuators! I am not sure why you have 2 of them. There should only be one. The T25's came from the 2nd gen eclipse/talons. They aren't really worth anything to someone who knows turbo's. They are small, inefficient, and can't spool over 14psi safely. You will have good throttle response with it though. But that is about it.
  2. MyFirst4G
    MyFirst4G Junior Member
    so, what is it set at? 14 psi?
  3. knowledge
    Beale AFB, CA
    Stock? Don't know off hand. Not 14psi though. I think either 7psi or 11psi.
  4. MyFirst4G
    Okay, so does it matter which wastegate actuator i use? or should they both be the same
  5. knowledge
    Beale AFB, CA
    Well by the picture they both look completely different. It almost looks like one of them wont even fit it. Try mounting both of them on the turbo and see if they both meet up to everything. If one of them don't... well then you know what one NOT to go with.
  6. looccm
    looccm Junior Member
    Ya, you shouldn't have two of them.
    The boost setting is determined by the size of the diaghram inside the little can at the end of the rod. It looks to me like they are both pretty much the same size meaning same boost setting.
    With the stock t25 you will see 8-10 psi. I know this because i had one on my crx. But you t25 doesn't look quiet like mine did (96 gsx) perhaps yours came off something else like an older 300zx, jdm silvia, ect. In that case your boost setting might differ.
