violent shaking
Discussion in 'General Tech and Maintenance' started by PHOBIA, Apr 2, 2004.
  1. PHOBIA
    PHOBIA Senior Member
    every damn day there is a new problem with my car.today when i was coming home from work"auctually leaving work" there was a loud pop like i ran over a bottle. the when i accelerate my car shakes real real bad.i crawled undernieth it and saw that a tie rod was pretty loose so i tightend it up .then i took it out for a spin and it just happends again out of the blue nothing.nothing.nothing then bam shaking like a blender.what could have poped that would make it shake like that?
    were going to put it up on a lift tomarrow but i need some direction tonight so i can snoop around..
  2. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    Check your upper and lower control arms. Any mods done? struts etc.? :unsure:
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    uhm, too many possibilities, my first vote for the pop would be a tie
    check your bearings... and ball joints
  4. MXDesa
    MXDesa Senior Member
    Queens, New York
    Ok, first thing i would do...
    1. Check for loose suspension components, Upper and lower control arms, tie rods, etc.... I doubt though that this is your problem.
    2. If your caliper is loose, meaning either the upper or lower bolt on the caliper bracket is off or loose, it wont make a sound while you moving steadily forward, then if you apply the brakes it will break it loose, and BAM cause the front end to shake as you describe. If you cant find anything loose whatsoever, go to the next step...
    3. If neither of the previous steps yielded any results, pull out your spark plug cables and distributor/Rotor. Check for arcing on your spark plug cables and a fouled distributor cap/rotor. If you see any sign of a missfire, perform a basic tune up...
    If after you do all of this and nothing happens let us know, if you find it, let us know too. One of these 3 steps will almost surely, solve your problem.
  5. PHOBIA
    crap.the whole shop was full when i was there so i went to work.when i drove to the shop i could not notice anything abnormal.so as i was leaving i stupidly hoped the problem corrected itself and did a burn out.seconds later it was back full force.
    1. its only when accelerating
    2. brakes is a diff story no big deal they just need to be switched
    the shaking is like a bad shopping cart. it feels like my wheel want to come off.
    i dont know if this helps,when i got this hatch it has some kinda 4 or 5 way adjustable suspension on it. and when i took hard corners to the right it would make this wierd noise like a scrapping,i just wrote it off as nothing serious. but know that it is making this same sound whale driving its got to be at fault. its on the left side and the car is pulling to the right...thanks for the responses,im taking notes and am hopefully going to get it checked on sunday"no cars at the shop to get in the way" thanks guyz
    oh,and would a bad distributor/rotor cause tha kinda shaking @ the wheels?
    if this is to be the problem what kinda rotor/distributor fits on a first gen b16a?can i get one off a 90-93 integra? thanks again
  6. PHOBIA
  7. uptowng2ic
    uptowng2ic Member
    NY
    As reck said could be the bearings....but fix that as soon as possible, had a similar problem...my old 90 teg would shake just like an old jacked up shopping cart..... on my way from PA to NY the car lost control on the expressway and slid across into the divider....luckily no one was hurt....it turned out that the wheel studs had broke, dunno why I had just change the axles, brakes and control arms prior to this....strange.
  8. PHOBIA
    well i took it to work and it was so bad that i just sed fuck it and left it at my moms house and cought a ride to work.i was going to drive it to the shop today but its to damn dangerous. so i guess im either going to tow it to midas or leave with a AAA card in hand and hope i make it.
  9. project90crx
    project90crx Junior Member
    I had a similar problem. It happened only during acceleration. My coil springs were cut and the car was near-slammed. I changed to some H&R Sport Springs and it went away. Just a thought....
  10. cws13
    cws13 Senior Member
    Athens,GA
    Which brings up a good point, if your car is too low the geometry of your axle is off. Violent shaking under accel. is often from inner axle joints gone bad.
  11. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    if you tie rod was loose is the ball joint loose
  12. hybrid4
    Nashville,TN
    Same thing occured when i put a used axle on my old civic. check axles ;)
  13. PHOBIA
    ok,i took off the 2 rods connecting to the front frame support.they were all fucked up.it the whole with the bushing is saposed to be the size of a dime, but it was moving around in there and it chewed it up to about the size of the bushing and was going to pull through.so i went to the pick and pull and got a new front frame mount and replaced it,come to relaize it wasnt the problem but that occured because of the problem. right before i got the car there was 2 brand new cv shafts put on .apperntly the passenger side cracked and was undetectable unless driven.so my friend sat ontop of the engine whal i drove a pointede it out. now its in the shop getting replaced with only shop fees and no cost of parts cuz there brand new and still under warrenty.thanks a lot guyz for your help.
  14. Import Builders
    Import Builders Senior Member
    LA, California
    this is going to sound pretty wierd, but it works.
    You know how you buy all the parts for a computer, then you put it together and it doesn't boot? Right? So you can't figure out, and you just unplug everything and start over, and then it works? right? Am I alone? lol.
    Anyway, take off the wheel, take the axle out of the hubs, and make sure its joins are ok, and the arms are all hanging there, and then put it all back together. Also, put the car in neutral, after your done getting stupid dirty, and elevated, SPIN the tire, does it spin easily? If it doesn't you need a wheel bearing. But the bearing won't cause your shaking. Thats caused from a control arm, or an Axle that has a BLOWN joint. When it blows, it will make a loud pop, and the black juice will squirt out somewhere under your car.
    Look for that.
    Problem solved.
    Jeff
  15. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    Yeah, Jeff's right about the whole ripping it apart and putting it back together idea. When I swapped out my girlfriends axles for new ones, it made a clanking noise when driving. I swore a bunch, sat for a minute and then just decided to start taking it apart. After I put it back together it was golden. :shrug2: Sometimes it just works that way, I guess.
